What gear ratio?
Discussion in 'The Garage' started by kgblazerfive, Feb 21, 2006.
What gear ratio
Poll closed Mar 3, 2006.
  1. 4:10
    12 vote(s)
    17.4%
  2. 4:56
    39 vote(s)
    56.5%
  3. 5:13
    15 vote(s)
    21.7%
  4. drive neked who cares about gear ratio
    3 vote(s)
    4.3%
  1. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,623
    612
    Hooper, Utah 84315
    I have a 60/60 combo, 350/700r4/203/205 drive train, looking at running 35 to 37 or so tires. Opinions on gears cause the rears have 3:54 in them now and I don't think that will work. Daily driver with some offroad use not to much hard core just want the ability to if I need too. Like to keep some gas milage.
  2. KingDuramax
    KingDuramax 1/2 ton status
    Jan 17, 2006
    451
    NY 14701
  3. Blazenkiwi
    Blazenkiwi 1/2 ton status
    Feb 19, 2006
    121
    Auckland New Zealand
    Yo dude, I am doing the very same thing as you at the moment, have just lifted the truck (85 K5) 4 inches and have MT 36" in Baja Claws, mine is a turbod 6.2 diesel/ R700 trans and have the 3.42 ratio, I tried it after fitting and it was useless, the engine was barely turning at about 40 mph in OD and converter lock up on.
    I am now importing a set of 4.56 from randys ring and pinion (you guys have got it sweet over there in the States, we pay through the nose to get bits sent down here) as a friend had done the same thing here and used the 4.56 ratio which makes it ok for wheeling and pretty good on the highway.
    Good luck with everything dude hope it works out for ya
  4. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i say put it in 4:1 low and see how you like it now. with that doubler you dont need the gears you may think in the axles, and you can keep freeway speeds with higher gears
  5. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Go with 4.56's. With the OD it will be great for a DD. With 35's Its only a couple hundred over stock gears n stock tires. Ive run 4.56's with 35's using a th350 and 700r4. Its a good combo. But if you plan 37's and maybe down the road 38"+ you may want to look at 4.88's or 5.13. How much highway do you see??
  6. kgblazerfive
    Dec 2, 2004
    10,623
    612
    Hooper, Utah 84315
    Alot of it is going to be around town and highway and stuff. I'm trying to condense my fleet so my Burb will be a DD/Tow truck /family camp vehicle. Thats why the 35-37 inch tires so I can still tow.
  7. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Then the 4.56's. They should give a close to stock cruising RPM. Thats hardcore when you have a doubler in your DD/tow vehicle. I would stay 4" with 35's. Thats what Im running and its a PIA loading a keg in the bed!! :D :haha: I keep cold beer on tap at home and do alot of hauling with my truck so I wouldnt go much taller.
  8. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
    Go with 4.88's. It will help with towing and you have od, so no problem.
  9. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    how fast to you drive on the freeway? ive got 4.56,35's and a 700r4, my truck is happiest at 75. any lower and its under the torque band. i iwsh i went with 4.88. with a heavier burb, plus possibly having 37's, i'd go 5.13's.
  10. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i vote for 5.13s gear once, not twice if u plan on bigger later
    i was originally going to do 35's and was looking into 4.56's. in the end i said screw it and went with the 5.13s. before i got the truck running again i found myself with some 42's in my hands. i would have shot myself in the foot if i had gotten 4.56's
  11. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    I just think 5.13's with a 35-37" tire that is a DD is too much. Too high RPM on freeway. The guy already has a trail rig.
  12. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    mines a dd :p:
    if hes goin to go 37's i think 4.88s would be a good compromise. he is going to be towing
  13. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    too much if you dont have overdrive. you'll still be under 3000rpm cruising 70-80 mph with 35-37's and 5.13
  14. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    I voted 5.13's. The extra power for towing will be nice and there is still o/d for the freeway. I have been running 37's on 4.10's for a couple of years now and it sucks on the highway, but I do have a dog motor.
  15. skidpan
    skidpan 1/2 ton status
    Sep 21, 2005
    226
    SOCAL
    not to hijack the thread, but I am going to be running a mild sbc, with a sm465, 205, and 38 inch tires.. what should i look into for gears?
  16. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Maybe. But I have run 35's with 4.56's with a 700R4 and it felt like it was stock. So I dunno if I would want to bump that up by 500 RPM if I did alot of freeway. But its doable. If it didnt see alot of freeway 5.13's all the way. I do 3000 RPM blasts on the freeway weekly 50 miles one way. Both in my truck and my Mustang that has 4.10's.
  17. kgblazerfive
    Dec 2, 2004
    10,623
    612
    Hooper, Utah 84315
    I would like to keep the rpm's in the mid two's either way I'm looking at new carriers also but I'm thinking 4:88 might be what I need
  18. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The 700r4 with the OD top gears is the key to the decision.
    4.10's with 35" tires would be marginal on the highway as you simply would not have much, if any, power when in OD. Your gears would be 4.10 x 0.70 = 2.87 equivalent in OD. With 37's OD would most likely be useless. Nobody will ever tell you that 2.87 gears are ideal for the street with this size tire, so why waste your time? My last two trucks have had factory 4.10's and about 31-32" tires with an OD trans and I drove both of them to work on the freeway at 70+mph each day at around 2,500 rpm.
    You could live with 4.56's but it would be marginal, not much better than the 4.10's. The equivalent ratio in OD would be about 3.20.
    With 5.13 axle gears it would be equivalent to about 3.60 while in OD on the highway, or pretty darn close to your current gearing. If possible get the truck running with the current gears with the bigger tires and cruise down the highway with the trans in 3rd gear (or D....just not in OD) and it would be about the same as the 5.13's with OD. Again, I doubt anybody will tell you that 3.60 axle gears are ideal for 35-37" tires if you had a non-OD trans, or that your highway rpm would be too high.
  19. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    yes this all works and makes sense, but you usually want you OD gear to be the low RPM cruisin gear to provide better mileage. Thats why its usually at 1900-2200 RPM in OD, to try n get some decent mileage while on the freeway. 2400-2800 RPM is more into the powerband but could be costing mileage. And odds are you will be downshifting at any hill anyways. So I guess it all comes down to what mileage you are looking for and engine output. If I was doing alot of freeway miles in a DD with small block I would want to stay at 2000-2200 on the freeway. If I just did short jaunts then 2500-2700 would be OK.
  20. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    I have 4.56s and a 700R4 and hardly ever use OD with 35s... go 5.13s. You're going to want them eventually anyway. Trust me.
    j
