What gear should i run after swap?
Discussion in 'The Garage' started by BigOrange90Jimmy, Jul 24, 2002.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Hey, I'm putting a 465/205 combo in my truck and I'm gonna run either 36 or 38" tires when i get it in. What kind of gear should i run to still be able to run 65-70 on the highway and have the engine at a reasonable rpm? i'm gonna run 16.5" wheels so figure that in if it's a factor.
  2. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    I've got 4.10's with the SM465/208,38" tires.I like it,plenty of highway power.Some will suggest 4.56...might be better.The K/5 is heavy,but I've lost the top,tailgate,half the doors,stripped interior,A/C&heater.So that is a factor.Go with 4.56 or even 4.88's...you can always get larger tires!!!Mike
  3. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    haha, that would be nice. what kind of rpm are you running on the highway? i want to keep the rpm's kinda low cuz my truck has the aerodynamics of a brick (mostly part to the HUGE front bumper).
  4. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    I have a 465/205 with 4.56 and 35s does about 3800 rpm at 65mph
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    What should I be running with a TH350/NP203(full-time that I wanna keep full time) 33"x12.50"x15". I have D44front and 12Brear with stock 3.07's. Want to know what to look for when I goto upgrade to 3/4ton D44/14B...oh and sorry for jumping in on this post.
  6. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    If you're going to run 33" tires then I'd say either 3.73 or 4.10s.
  7. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    it's no prob since we're on the same subject. So 4.56's and 38's i should be around 2500 rpm's or lower?
  8. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I've been running the 465/205 and 4.10s on 38s for 3 years now. It works fine, not worth changine, runs about 2300RPM on the freeway. If I were to swap gears in for this setup I'd probably go with 4.88s but, if you want to run 70 at low RPMs I'd go with 4.56s. Like I said, 4.10s are fine, but 1st gear (not granny) bogs just a little bit coming off from a stop, so 4.56s would be better.
    Not to hijack your post, but since people reading this are thinking about the subject anyways I'll ask for opinions on what gear I should go with after getting my 14b/D60 combo in. I'm going to be on 38s until they wear out, then go to 42s. I'm leaning towards 5.13s, they're going to suck until I get the bigger tires, but I want to be ready for the bigger tires. I've done all the calcs and such, just looking for personal experience. I don't feel a need to go faster than 65 in the truck, so speed on the freeway isn't a huge issue. Not a DD either, it's only driven on the street to get to trails, but sometimes as far as 200 miles to get to Pismo. What is the maximum RPM that is safe for a sbc to turn for extended periosds on the freeway, and at what point will mileage start to drop considerably? </font color>
