What gear??
Discussion in 'The Garage' started by 85mudblazin, Jul 19, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I have a 700r4 transmission with a 350 engine and I currently have 3.08 gears and I have 35" tires which I plan on swapping for 38's later down the road what is a good gear choice for a blazer that sees mostly street uses but wil also be very good off road??
    -Chris
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    5.13's
    Harley
  3. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    d60 and a 14b. wouldn't even bother putting money into those 10bolts if you going any bigger. you'll be glad you did! but gear wise...i'd go 5.13's...your OD will make up for it.
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yea I have the 14bff ready to go just need to get the gears in and it will be ready, so would the 5.13's be to much for my 35's or will I have crazy power?? /forums/images/graemlins/thumb.gif
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I have 35's with 350/700 and 4.56's and wish i had went with more gear so someday i am going to go to 5.13's.
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am in the exact same boat you are. Regeared to 4.56 and it isn't enough. I run a 350 and a 700R4.
    Harley
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Almost sounds like we need to make a collection of people who did not gear correctly the 1st time then make a group purchase of gears and have a gear swapping party. /forums/images/graemlins/waytogo.gif
  8. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/thumb.gif
  9. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I ran 36" tires and 4.88's for a while with my 700R4 and I loved it. I think 4.88's are a great gear opposted to 5.13's. Although I did choose 5.13's for my current setup (350/465/205) because I'm running 40's and a 1.96:1 t-case. If I had an NP241 t-case with a 2.72:1 low I'd run 4.88's. I do a lot of mud though, I guess it just depends on the terrain you travel and the power band of your engine.
