What gear?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Flyinhi86, Jun 9, 2001.
  1. Flyinhi86
    Flyinhi86 Registered Member
    Mar 31, 2001
    51
    Ft McMurray, AB, Canada
    I have a 700R4 tranny with 3:73 gears, 350 motor and 35" tires. To save the tranny from burning out should I drive it in overdrive all the time. Should I be worried about possible tranny, motor problems with this setup.
  2. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Driving it in overdrive would probably hurt more than help...unless you are driving 75 or something. With only 3.73's and 35's, its going to be lugging around at a lower RPM anyway...add an overdrive to that and it gets way worse...the engine won't even be close to its proper powerband anymore. 4.56 gears would be alot more suited to 35's....even 4.88's would be fine since you have the overdrive.
    '73 K5
    Chevy good...Ford bad
  3. KENT
    KENT 1/2 ton status
    139
    Roseburg, OR
    What is the proper power band (RPM) for a 350 motor? Does FI make any difference?
    I'm running 33" with 3.42 gears in my 89 blazer (250/465/241). It doesn't seem to lug down noticably. I am upgrading to 3.73 with 35-36" tires and though that would be about right.
    Am I totaly off base?
    Kent
    1989 K5
  4. '73 K5
    1,763
    Kansas
    There are websites that have gear calculators on them so you can type in your tire size and gear ratio and it will tell you what cruise RPM will be at 65 mph. Maybe someone else can list a link to one of those websites, because I can't remember any off the top of my head.
    I think most of the guys here would agree for a 50/50 payoff between offroad and highway driving that 4.11 gears are a great match for 33's. Thats what I have and I love it. 4.56 gears for 35's or 36's...and so on.
    '73 K5
  5. fatdog
    fatdog Registered Member
    Jun 1, 2001
    59
    Soda Springs Idaho
    Try this calculator link, http://www.randysringandpinion.com/RPMCalculator.html not sure about the actual accuracy, but maybe some of you can verify with your current set-ups.
    Rob
    '65 Turbo Corsa
    '69 Elcamino
    '71 Chev 4x4 Short Step
    '71 GMC 4x4 Long Fleet
    '72 Chev 4x4 K5
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    What about what they say when driving around town, keep the tranny in Drive mode and when on the highway, keep it in the Overdrive mode?
    <font color=red>I m so we Todd did.
    I m sofa king we Todd did.</font color=red>
  7. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Power band for a 350 is 1800 to 2800 rpm at 60 MPH.
    <A target="_blank" HREF=http://www.ring-pinion.com/>http://www.ring-pinion.com/</A> And go to calculator........Dan
  8. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    To save the trany get a big cooler. 700r4's hate heat. There are also kits out there that will lock the converter up sooner (by speed insted of just in 4th gear) to keep it from making heat but you would need enough power to have it lock up sooner.
    '71 Blazer CST with alot of rust
