What gearing do I have?
Discussion in 'The Garage' started by IL84JIMMY, Apr 13, 2004.
  1. IL84JIMMY
    IL84JIMMY Registered Member
    Feb 24, 2002
    29
    Northwest Illinois
    I drive an 84 Jimmy, stock with a rebuilt 350. I dont really konw what the owner before me did to it. How can i know what gearing i have. The truck is a manual with granny gear and then the three speed. When i am running on the highway at 60, my rpm's are at like 2200. Thanks
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    how tall are the tires?
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    jack up the rear of the truck and turn the tire one full revolution and count how many times the drive-line makes a full revolution. drive-line turns 3 and 3/4 turns 3:73's 4 and 1/4 turns 4:10's
  4. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    wouldn't you have to turn the tire two revolutions if it is an open diff?
  5. IL84JIMMY
    Feb 24, 2002
    29
    Northwest Illinois
    tires are just 29 inch AT's for daily driving
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    3.08's
  7. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Using the calculators at www.4lo.com I come up with you having 3.08 gears (assuming the numbers you gave us are accurate).
  8. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    thats where i went. I love thier alcohol level calc. too,LMAO
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    well 350 wouldnt be in the truck from factory,
    if your SPID label says GQ1 standard axle then youre gonna have to pull diff cover and look on the very edge of the ring gear it will have teeth count(of pinion and ring both- divide these to get the axle ratio) stamped into it along with date and ring gear part number or find stamping code on RH axle tube and call chevy parts counter with the code and year make model of the truck,
    in 84(10 bolt 8.5") it can be 2.73, 3.08, 3.42, 3.73
    good luck
