what gearing in 74 k5 12 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by az88k5, Oct 26, 2006.
  1. az88k5
    az88k5 1/2 ton status
    Oct 14, 2004
    258
    Prescott Valley, AZ
    I have a twelve bolt out of a 74 k5. I need to know what the gear ratio was in this stock. does any one know? Thanks any help much appreciated
    #'s are as follows 11 2 73 Dana 18515 A3D87 41-11
    Are these 3.73's or what
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    pop the cover and either count the teeth or read the numbers on the ring gear
  3. az88k5
    Oct 14, 2004
    258
    Prescott Valley, AZ
    The pinion fell in and I can't turn the ring gear or I would, and its not worth pulling the axles and carrier. thanks for the info though
  4. 84PolarBear
    84PolarBear Registered Member
    Feb 19, 2002
    86
    San Francisco
    It should be 3.73
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    not necessarily....i've seen 3.08's, 3.73's and 4.10's all being stock for that yr
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Bit of trivia , 3.08's in a 12 bolt are actually 3.07 and a bunck of decimal places :wink1:
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    paul, on my old 1/2ton stuff (D44/12b) the numbers came out to 3.07 on my 44 and 3.08 on the 12b :dunno:
  8. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If it was auto it should be 3.08
    If it was a manual they had the choice 3.73 and 3.08
    Although you could always have custom gearing, but standard for 74 was those numbers.
  9. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    My 74 came with 4:10's.... so you'll need to pull the cover and check manually....
  10. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Do you know for a fact it was stock?
    Was it with a tow package?
    What engine did it have? the 400 SBC came with higher gears too.
  11. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    1974 K-5, Trailer Special, 350/350/203... and yes it's on the RPO as 4:10's....
  12. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yeah I forgot about special editions like trailer, HD, tow package, those came with different gearing, but they were noted, badged as such.
    Most production lines were the same as described above. :D
    I had lots of spec sheets from the dealers in the mid 70's that is why I know a little bit about this.
    They had a little more info than the sales broshures.
    :wink1:
  13. nau81blazer
    nau81blazer 1/2 ton status
    Mar 6, 2004
    329
    Cincinnati, OH
    Did you happen to fix this yet? I really need some 3.73 or lower that I can just bolt in...Thanks.
    Adam
  14. az88k5
    Oct 14, 2004
    258
    Prescott Valley, AZ
    No I'm not going to fix it, I don't have the yoke for the pinion.
  15. az88k5
    Oct 14, 2004
    258
    Prescott Valley, AZ
    heres the #'s off the ring gear
    11 2 73 Dana 18515 A3D87 41-11 389
    Are these 3.73's or what????
  16. 1BEATK5
    1BEATK5 1/2 ton status Premium Member
    Dec 15, 2005
    2,735
    32
    beaverton orygun
    41-11 means 3.73 41 ring gear teeth divided by 11 pinion tetth gets the answer
  17. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yep 3.73 and this is the original for your 74, built november 73.
  18. Gorillajeep
    Gorillajeep 1/2 ton status Premium Member
    Sep 7, 2006
    238
    Myrtle Beach, SC
    What gears did the 400 SBC have? You brought it up. . . .
    James
  19. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well supposedly 3.73 or optionnal 4.10 no 3.08.
    :confused:
    As for my "original for you 74" I meant gears said 11-73 so late 73 for a year model 74 so most probably still the original gears.
    :D
