what gearing is in my pumpkins?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Sep 23, 2001.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I know how to count the stinking rotations but I always get confused when I'm counting (I know how to count, so that isnt it...) I know I count the wheel revolutions and the driveline revolutions... then what???
    Is there a easier way???
  2. flblazer
    flblazer 1/2 ton status
    Nov 24, 2000
    149
    tampa fl
    go to www.4lo.com it will help u
    can some 1 find me a ford i need to take a pee still peein on that ford just have to keep goin dam i can not stop pissin:) k5s kings
  3. 74Roadster
    74Roadster Registered Member
    Sep 20, 2001
    30
    North America
    Pull the cover [​IMG]
    74 roadster in progress [​IMG]
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    An easy way to get a good guess is to tape a piece of string to the driveline (on bottom), tie a washer to the hanging end of the string - now move the rig forward for one revolution of the wheels, then count the number of wraps the string makes around the driveshaft. It won't give you an exact figure, but will get you pretty close.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  5. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    a gasket for the rear is $5 and gear oil is another $5. When was the last time your diff oil was changed and your gears were inspected?
    My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
