what gears are in a 3/4 ton axle
Discussion in 'The Garage' started by big_bad_blazer, Mar 31, 2003.
  1. big_bad_blazer
    big_bad_blazer Registered Member
    Sep 19, 2002
    22
    yankton, SD
    i have one quick question, what gears usuly come in the 3/4 ton chevy danna 60 stock
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    410, but if your lucky, they are 456, if your unlucky they are 373
  3. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    All depend's on how the truck was ordered. Most truck's of the 70's were ordered with 3:73 for gas mileage. /forums/images/graemlins/rotfl.gif
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I'll assume you mean the 14 bolt rear-end. They didn't have dana 60 rears. And, the 3/4 ton's didn't use dana 60's up front either, only the one-tons.
    Anyway, to answer your question, it depends on what tranny/options the vehicle had that it came out of. Rough estimate, I'd say 60% have 4.10's and 40% have 3.73's. There is no good way to know unless you pop the cover - not a bad thing to do anyway especially if you're buying from a junkyard.
  5. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I was thinken the same thing about the D60
  6. big_bad_blazer
    Sep 19, 2002
    22
    yankton, SD
    Well I looked on the back of the axle, on the right side of the cover and it had the serial # and it said 60 right below that. I got it for free so it might not be a 3/4-ton /forums/images/graemlins/ooo.gif. I though it was . it looked like one. How can I tell? If it is a ton that is better /forums/images/graemlins/thumb.gif
  7. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    before they put started putting 14bolts in they had d60's in teh rear. from what i've gathered they are usually 4.10's.
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    it can be anything....ive seen one with 3.23's pop the covers and look. if your lookin to buy one its stupid to buy without takin a look at the gears. If its on your truck, its a good time to change the gear oil
