What gears do i have
Discussion in 'The Garage' started by 84CUCV, Jan 13, 2007.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Well, got off my butt and pulled the cover. these are the #s from the ring gear:
    2gm39885151041481
    i have no clue how to read that
    thanks
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    are you sure you got it all. and did you leave some spaces out or somthing?
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    i did leave some space out. didnt think it mattered. Should there be more #? thanks
  4. sweetk30
    Nov 1, 2004
    25,526
    526
    please copy it as it is on the ring gear. and dubble check it. i tryed to find any combo with what you had and could not.
  5. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK here ya go...
    2 gm 3988515 10 41 4 84
    that is all that is on the ring gear.
    thanks for the help
  6. sweetk30
    Nov 1, 2004
    25,526
    526
    10 in to 41 = 4.10 gears and then made 4th month of 84. good luck
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    thanks !!
  8. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    1041481 = 4.10's BLT 4 81
    2gm39885151041481= 3988515 10 41 4 81
    Manny
  9. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Just count teeth and divide ring by pinion.
  10. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    x2
    I looked at mine and there was the faintest mark saying 410. Figured there be more numbers and letters like what you had. Counted the ring and pinion (twice to make sure) and it ended up being 4.56
  11. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    without removing the carrier, how exactly do you count pinion teeth? I guess i'm not that patient:confused:
  12. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    I jacked up the rear and had someone turn the tire while I counted I think. And also made a small mark to remember where I started counting
  13. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Theres no need to count the teeth. You have 4.10 gears. Your axle was made in april of 84. Ive seen so many of these ring gear stamps.....the instant I looked at your initial post with all of the numbers not spaced out I knew it was 4.10's. Counting the teeth on the pinion is a pain in the a$$
    -Harrison
