what gears do my 10 bolts have?
Discussion in 'The Garage' started by 88jimmyoungowner, Jul 16, 2002.
  1. 88jimmyoungowner
    88jimmyoungowner 1/2 ton status
    Nov 20, 2001
    425
    georgia-rome
    what is the easiest way to tell? im just wonderin becasue i want to know mostly for general knowledge. thanks.
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    You have an 88 according to your sig. The ratio should be in the glove box on the sticker thats on the door. If its not there or you think the gears have been changed youll have to open the diffs and read the #s on the ring gear.
  3. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    from my expereience and maybe im just generalizing this,but most 1/2 ton trucks and blazers ive seen come stock with 3.73 to 1 gears.i have had 2 diferent 12 bolts and they were that ratio.when you get into 3/4 ton stuff i have seen mostly 4.10 to 1 ratio gears.the best way to tell is open the diff cover and look and the stamp on the ring gear and see what numbers there is on it.divide the big number by the small and then you have your ratio.3.73 would be stamped 41.11 which means 41 ring gear teeth and 11 pinion gear teeth.hope this helps /forums/images/icons/laugh.gif
  4. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    ive aquired over 4 sets of ten bolts, all 3.07. <font color="blue"> jack th truck up, spin the tire once, count the driveshaft revolutions and thats the ratio </font color> <font color="red"> tire revolutions, to driveshaft revolutions </font color>
  5. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    usually easier just to read the codes from the glove box
    Later
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    On my burb, I have the sticker on the glove box door, but there is no code...there is though a tab on one of the bolts on the rear 12b saying 3.08.
  7. JohnnyFresno
    JohnnyFresno 1/2 ton status
    Mar 24, 2002
    194
    Clovis, CA
    I'm pretty sure most 10bolts are 3.08's
  8. loudnowlouder
    loudnowlouder 1/2 ton status
    Jan 29, 2001
    539
    Ellicott City, MD
    i have an 85 custom deluxe with the towing package installed, it had stock 3.73's with posi in the rear, it said this in the glovebox, and when i pulled the cover off it all matched up...
    so if your glovebox doesnt tell you what you have, the only real way to tell is to pull the cover off and see
  9. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    Of the 4 axles I have two are 3.42:1, one is 3.73:1 and the other is 2.73:1.
    If you haven't owned since new, pull the cover and look at the stamping on the ring gear. 3.73:1 is usually 41-11, but divide the big number by the little number and then you'll know for sure. Besides, it wouldn't hurt to give her some fresh gear oil.
    If you just got the truck and haven't tried out 4x4, don't assume that the front and rear are the same. I made that mistake... /forums/images/icons/crazy.gif
    John
  10. StonerK5
    StonerK5 1/2 ton status
    Feb 13, 2002
    183
    Phoenix Arizona
    Got an 84, when I bought it it had 2:73's...till I spit most of them out on the road. /forums/images/icons/shocked.gif
  11. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    My '87 K5 came with 3.73, I know that the 10b came with 3.08, 3.73, 4.10 (rare), I'm not sure what they put into the car axles.
