What Gears do you run with 35s
Discussion in 'The Garage' started by broncoman6524, May 21, 2006.
What yer ratio
  1. 4.10
    55 vote(s)
    46.2%
  2. 4.56
    51 vote(s)
    42.9%
  3. Other Please Specify
    13 vote(s)
    10.9%
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    Alright my dad is going to look at a lift for his truck that comes w 35 bfg M-t that he doesnt want:D What ratio do yall run with this size of tire. Im not sure yet if i'll regear my axles or if ill go to the yards and find 3/4 tons with the right ratio.
    This is an 84 k-5 350/th400/208 and 10b's
    One more Noob question I've already got AAl's, to run 35s all i'll need would be either a shackle flip and 4" front spring. Or could i run a 2" or 3" BL and clear it
  2. MT wheeler
    MT wheeler 1/2 ton status
    Nov 14, 2005
    197
    Billings, MT
    That depends
    A "general" rule of thumb is to multiply .12 by the tire size you want to run and that will get you pretty close.
    .12X35=4.2 so 4.10 would probably be just fine.
    It also depends on what the truck will be used for...DD, off road, towing, etc.
    Hope this helps.
    I run 4.56 with my 38x12.50's and it works out fine for all around.
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    I am currently running 4.10's with the 350/700r4/35" tire combo, and actually could probably use alittle more, it tries to hunt too much while at highway speeds between O.D. and 3rd, i have to "push" it to get it into OD, but then when i let off to try to cruise, it will loose speed and eventually drop back down into 3rd as i try maintain the speed.
    These are of course speeds of 75+ out here in Arizona :p:
    Maybe i am just going too fast with a vehicle with the aerodynamics of a brick? :D
  4. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    I think it depends on what tranny you're running too. I've got SM465 with 4.10's and 36's and it's turning a little too much rpm for me on the highway. I'm probably going to stick with the 4.10's when I go to 38's just for the highway manners. Although I'll eventually go doubler for the slow moments. :D
  5. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    In my Blazer with a 350/400 I'm running 35 BFG mud terrains with 4.56's.
  6. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Right now 4.88's. But I have 37" tires waiting to mount up...
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've got 4.10's on the rig with no overdrive. 4.56's on the one with overdrive. :cool1:
  8. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Running 3.73 gears with my 35's. Turns around 2850 rpm at 70 mph. The doubler drops the ratio enough for the off-road stuff.
  9. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    4.10 with the 700r4 is a nice highway friendly set up. Sometimes I think maybe I should've gone with 4.56 but it's a close call.
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I have 700R4 with 4.56 and 35's but need more gear so in the future 5.13's will go in.
  11. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Where is zakk when you need him?
    5.13s of course.
  12. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    right now i have 4.10s but looking to go to 5.13 and 37s
  13. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    I ran 4:56 gears in my 78 for a while 350/350/203 and I had hard time on the highway... So you need to think on how your going to use your truck mostly....
  14. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    355/465 with 3.73's on 35's.
  15. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    th400 with 4.10 and 35's. 4.56 will be in soon.
  16. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    5.13's
    but its to much
    works better with the 42's on
  17. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i had 373 with 35s and that was fine. if you had overdrive i would say to go with 5.13s, but u dont have od. go with 4.10s
  18. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    491
    New Hampshire
    I've got 35s and the SM465 with a set of 4.10s. They aren't bad on the high way, about 3000rpm is about 75mph. I don't go too long on the highway. But around town the 4.10 is perfect ratio. On the trail I never had a problem with gearing. Then again I have a 6.55:1 granny gear :)
  19. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    i run (sm465) 3.73 with 35's does ok for me but rpms are a little higher on the highway than i like so i might go back to a 37'' tire when these go.
  20. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    I have 4.10s with the 700, and I absolutely hate it. I'm going to 4.88's, and a 465, when I through the 38.5's on :) well it will be the 465, then 38.5's then gears.
