what gear's for 35's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazingboy, Dec 4, 2001.
  1. blazingboy
    blazingboy 1/2 ton status
    Dec 2, 2001
    120
    Georgia
    what gear\'s for 35\'s
    Could I run 35's on the street with my 3.73 10 bolts.
  2. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    Re: what gear\'s for 35\'s
    yup you could, my friend does it with 3.08s. if you have overdrive go with 4.56s and if you don't go with like 4.11s. i think i've seen 4.33s before too. the 3.73s aren't the prob. i have 3.73s with my 36"s and i do alright (for the time being), it's the 10 bolts i would worry about. i don't know though i'm a 3/4 ton.
    people that get good mileage aren't having any fun!
    scott,
    1989 GMC suburban 3/4t 4" lift finally rollin on 36" swampers, tbi350, th350, np241
  3. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    Im running 35s with 4.11s and they work great, you could do it with 3.73s though
    79 Jimmy, 5" lift 35 M/T with a 383 puttin out 400hp and 450lb/ft. Locked front and back.
  4. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    What kind of gas mileage would u get with 35's and 3.73s and 700R-4? Can you even put it in OD??
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Probably pretty crappy unless you had a really torquey motor, you're risking burning up the tranny, and, no, you really couldn't put it in OD unless you had quite a bit of torque (more than a stock 350 anyway).
    I have 4.10s and 35s with a 700R4. Even this isn't enough gear. I would swap to 4.56s if I wasn't putting in a 4 speed.
    Tim
  6. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    You could run 3.73's. I myself am way glad I went w/4.56 .
    If mostly street & some freeway do 4.56. Around town it's
    pritty snappy and on the freeway in OD I run with the flow
    of traffic @ around 2300 or 2400 rpm.
    88 5.7 5in lift 35"procomp at's
    700-208-456-3in exh w/flowlowder 10 bolts & some ORD stuff
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    I've had 4.56s as long as I've had 35s...its a good combo, and if I wanted to run 37s or 38s, it wouldnt be a BAD gear either...so tire upgradability with the 4.56s is a lil bonus.
    J
    See the on-going build up of my '85 Jimmy! http://community.webshots.com/user/jekbrown
  8. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I ran 3.73s with 35s for a while with a tired 305. It did okay, but forget about OD. I swapped to 4.56s and have never looked back.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  9. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    hah, i think ive had it really bad. I had 35 BFG mud terains on 3.08's with a 305 that has worn out piston rings... if you dont know what that means that means ive lost ALOT of compression and prolly putin out less hp than some honda civics! Of course i have 4.56 now and I love them... I can still drive highway but not fast prolly aound 60-65 at the max.
    Thats with a 4spd manual tranny, if you have overdrive then 4.56 will be badass. As for your question of being able to run 35's on 3.73's hell yeah you can. If i ran my 35s on a 100hp 305 with 3.08's you can run em with 373's.
    6in 87' K5 w/ 35" BFG muds.
    305/Sm465/ NP208
    Kn, 4.56's.
    In desperate need of a rebuild.
    Next- Eaton mech locker... Flows.
  10. blazingboy
    Dec 2, 2001
    120
    Georgia
    So why coulden't I use overdrive and why would it burn up my tranny.
  11. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    The torque converter locks up around 2,000 rpm. Under that it's designed to slip. If your gears are too high then the torque converter won't lock up and you'll get a tremendous amount of heat which kills auto trannies expecially a 700R4. I've got a TH350 and i'm going 4.56's with 35's. I plan on putting an OD in my truck.
    Don't hit me, Mr. Moderator... I'll go back on topic... I swear![​IMG]
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer>www.geocities.com/muddin4fun79blazer</a>
  12. JROSS
    JROSS 1/2 ton status
    Oct 12, 2001
    281
    Redding, CA
    I run 35's and 3.73. It will get you around town and on the freeway o.k., but accel is kind of slow. I plan to upgrade to 4.10's. I have TH350, no OD.
    81 Blazer Silverado Package, 350, 4" lift, 35" tires
  13. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    The RPMs would be too LOW in overdrive (below your engines powerband)....so there wouldn't be enough power to keep it there.
    As far as the transmission.....the higher gears (lower numbers) don't give you as much torque multiplication as a lower gearset would. Using low gears takes a lot of load off the engine and transmission.....and that reduces heat.
    It's kind of like trying to pedal up a steep hill on your 10-speed in the wrong gear.....you're LEGS start to burn because the gears aren't helping to get you up the hill. That's what is happening to your transmission when you ask it to move the weight of your truck &amp; heavy tires without a decent gear. But in that case, it's the slippage of the torque converter that causes the heat.....
    Sometimes I think people blame the transmission (or builder) for failures, when in reality they just have a truck with poorly matched components in it.
    -Greg72
    '72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
    <font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
  14. blazingboy
    Dec 2, 2001
    120
    Georgia
    The fastest I would probaly ever get would be about 60 to 65
    would that matter that much
