what gears for my combo
Discussion in 'The Garage' started by GMC500, Jan 23, 2006.
  1. GMC500
    GMC500 1/2 ton status
    Aug 19, 2005
    203
    Safwa
    hello all
    I tried to do a search with 3.73, 4.10 or 3.42 but with no success
    Sorry - no matches. Please try some different terms.
    anyway
    my combo
    1986 GMC k1500 shortbed pick-up
    stock height - no lift YET :rolleyes:
    350 sbc
    L98 aluminum heads
    comp Xtreme 4x4 12-239-3 cam
    CR 9.0 - 9.5:1
    edelbrock performer intake manifold
    stock Q-jet :confused: ( will be replaced with ....... ? )
    stock exhaust manifolds ( I'll buy long tubes ASAP )
    dual 2.5" exhaust + glasspacks
    stock HEI dizzy + MSD in-cap coil and module ( OK it was stock :D )
    SM465 + np205 + stock 10-bolts
    I've opened the rear-end and it is a limited slip unit with 40:13 stamped on the ring = 3.07 :doah:
    33" tires ( actual size is about 32.7" )
    I'll use it in sand dunes no rocks, no mud
    what gears should I use ?
    thanks
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    You said "no lift...yet". So I think you should do your lift and then decide what size tires you will end up with. Do you do any street driving with it?
    Then decide what gear you need.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    As far as the search it will not look for anything less than 4 characters which I dont believe a period counts. Try a wildcard by placing an * in front like *3.73, *4.10.
    As for gear choice it is a 10 bolt I would not waste the money but if you must I vote for 5.13s:D .
    Also are you sure it is a limited slip and not a gov-bomb? Does it have springs between the spider gears in a normal looking carrier or does it have some machined blocks with a carrier that looks like 1 side has been cutout.
    Ira
  4. GMC500
    Aug 19, 2005
    203
    Safwa
    I don't have plans to use bigger tires
    but I'll do maybe a 4" lift in the future
    and yes I do drive it on the streets but it is not my daily driver
    sorry I thought they were the same :D
    it has a big S shaped spring in the middle and some clutch plates in the right
    what do you call it ? :confused:
  5. sandawgk5
    Oct 28, 2003
    6,881
    Ya the s shaped clip is what provides the preload to the clutches in I think an auburn limited slip. A gov-bomb is obvious it has all kinds of pawls and a huge H shaped block a little governor thing and some clutches on one side. I was not doubting you just trying to make sure of what you had.
    Ira
  6. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    With 33"s and assuming a no-overdrive tranny I would say no numerically larger than 4.10. So 3.73 or 4.10. If you do much highway driving, no bigger than 3.73.
  7. GMC500
    Aug 19, 2005
    203
    Safwa
    thanks a lot
  8. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    If it has 3.08s like mine, then it prolly has a gov-bomb. I doubt someone would drop the money for a limited slip and stay with those gears. I got 2 12bolts-308s and gov-bombs. Might wanna look at getting a locker for it.
  9. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    if it's just sand I'd say keep the 3.08's and get some bigger/wider tires when do the lift.
  10. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Well if you want to keep a top speed of more than 55 I say go with a 3.73. A 4.10 might be too much without overdrive. I have a symilar combo, with the SM465, 3.08 10bolts, and 35s. I have already done a gear swap to a 4.10 and at about 65 I'm churning at 2800rpm. So if you had 4.10s you'd be over 3000rpm screaming dowm the highway.
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If you have no intention of going bigger , and no intention of running rocks , and since you have a sm465 and a nice 350 .
    Get experience first and decide what you want to do .
    I had 3.08's with 33's before , and it was slow off the line , but was liveable for awhile until I scored lower axles cheap .
  12. GMC500
    Aug 19, 2005
    203
    Safwa
    pauly383k10
    yes I have to test it first
    but unfortunately I don't have time now due to final exams :doah:
    maybe after 2 weeks :D
    thanks
  13. gm500hprat
    gm500hprat 1/2 ton status
    Feb 28, 2005
    196
    anaheim, ca
    My buddy had a 73 longbed with 33's and 4.11's in the sand its an awesome combo.get some serious performance.He was by far the fastest street truck up the hill at the sand dunes...But I guess the 350 hp 400 sb probably helped some too..;) ....It was doable on the highway if you werent going beyond 60-65 range...
