what gears is everyone running I'm trying to decide?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by slider79blazer, Sep 25, 2001.
  1. slider79blazer
    slider79blazer 1/2 ton status
    Mar 23, 2001
    164
    littleton,co.
    what gears is everyone running I\'m trying to decide?
    I have a 79 w/400C.I. 350 turbo auto. w/ 3:73 gears 35-12.50-15 mudders. I'm trying to decide if I want 4:11 or 4:56 gears. it is my daily driver so I want it somewhat good on the roads but I want it to hold me back on the trails also. right now the 3:73s don't slow me down at all I have to ride the brakes down the trail. let me know what you all run and are you happy with your choice?
    <font color=blue>whats a 4 letter word for farm wagon?-- ford</font color=blue> [​IMG]
    <a target="_blank" href=http://community.webshots.com/user/slider79blazer>http://community.webshots.com/user/slider79blazer</a>
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Re: what gears is everyone running I\'m trying to decide?
    I have the 700r4 with 33 inch tires and run 4.56.. It is not my daily driver thou.. And I have the overdrive.. Dan
    If it ain't broke.......Don't fix it....
    <a target="_blank" href=http://coloradok5.com/gallery/Gokartergo>KLICK</a>
  3. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    I'm running 3.73's with 35's. Not bad but I was running 31's with these gears before. I'm going to 4.11's next summer. Going to a 400cid from the 350cid helped but still miss that extra torque.
    78-K5 4"Lift 35"Tires 400SB TH350 NP205
    73 Vega 350SB TH350
  4. slider79blazer
    Mar 23, 2001
    164
    littleton,co.
    I went from 33s to 35s runs great on the road and climbs uphill good but coming down I want to crawl but the gears are just to hi I'm thinking on the 4:11s also.
  5. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    with no OD I wouldn't got over 4.10's... I got 35's with 4.10s and at 75 I'm running about 2900 RPM...
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  6. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I'm running 3.73's currently, and plan to go with 4.11's when I get my new axles in.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  7. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I am putting 4.56s in the Jimmy as we speak. It has 350, 700r4 and 35" Goodyear MTRs. I will be putting 4.10 in the burb shortly. It has 350, 700r4, and 35" BFG MT
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  8. slider79blazer
    Mar 23, 2001
    164
    littleton,co.
    if I put 4:10s in will that slow me down on trails or will the tranny still pull me down fast?
  9. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    I am also debating about what gears to use. I'll probably go with 3.73s, 35s, with a sm465 tranny.
    ARQ.
    offroad baja!!!
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>http://coloradok5.com/gallery/ArqDennis</a>
  10. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    410's with 44's and an sm465
    <a target="_blank" href=http://www.whiteknight.scriptmania.com/>http://www.whiteknight.scriptma
    nia.com
    </a>
  11. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I've got 33's with 4.10's and the 700R4
    89 K5 Silverado
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  12. steve85fla
    steve85fla Registered Member
    Mar 27, 2001
    83
    palm beach county FL
    I'm running 4:56 with 35" tires and a 700r4
    my opinion 3:73 to 4:11 is not going to make a big difference for you, you might want to consider 4:56-you can always go up in tire size
  13. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I've got 4:10 with 35 BFG AT's It works alright off road as for the down hill stuff If I'm in 1st gear and Lo-4 It does great.
    Eric
    <a target="_blank" href=http://cethern.tripod.com/erics-home-page-and-other-stuff/>http://cethern.tripod.com/erics-home-page-and-other-stuff/</a>
    AMSOIL Dealer # 529948
    Cethern@interfold.com
  14. slider79blazer
    Mar 23, 2001
    164
    littleton,co.
    eric do you have a automatic or standard?
  15. Grim-Reaper
    7,385
    Atlanta
    If you had the 465 I would say the 465's since you will not have the slip. I just put 4.10 in mine with tall 32's. Should be ok with the 35's I'm tunning 3000 rpm at about 65-70 (speedo is off). BigJBear is running 4.65's with 35's and loves them on the trail but for running down the hwy it is turrning some RPM's. He has a 80 with lock up converter so it's not quite as bad as a 79 would be with no lock up. If you do a lot of hwy I would say go with the 4.10's I('m debating 33's or 35's right now.
    I don't need no damn shop manual, I got a pornographic memory.
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    Grim-Reaper
  16. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
  17. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    4.56's, NV4500 &amp; 33" tires. 65mph = 2200RPM in 5th and 2900RPM in 4th.
    A good firm grip is my idea of gun control!
  18. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    you know what I haven't done much rock crawling, but I have done a LOT of hill climbing with this thing. I can tell ya what I have absolutely no desire to have a lower geared axles.
    now, in my k5 that has a 700r4 I'm running a 31" tire with 4.10's and I absolutely love the combination. I have OD there though.
    the sm465 has really low gearing... and I also have the np241 which also has really low gearing. now if you got an np205 I would say you gotta drive the thing a bit off-road before you decide.
    my k5 is not a dedicated trail rig because I use it for a lot of daily driving also. I'm not willing to make this thing so trail ready that I don't like the way it drives on the road.
    if it were me a touch higher gearing in the t-case would not pose a problem... when I put this thing in low / low it really creaps. I like the combination I got right now.
    another thing you gotta consider is if you 35" tires are really 35"... unless you are running an interco tire chances are you really don't have a 35" tire. my 35" tires measure exactly 33" so I'll be going to an interco 36" tire when these are run out. I probably will not change the gear ratio either, but we'll see. depends on how well the new engine will turn those tires.
  19. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    leave your gears alone so you can fly on the freeway and add a doubler to crawl off road.
    the absolute best combination. wish it had been available when i did my drivetrain the first time and i wouldnt be saddled with 4.88 and 39" tires cruise rpm on the freeway about 2600 rpm 55mph
  20. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    4.10's and 33's. I couldn't be happier. I used to have a Jeep with 35's and 4.56's and it was a great combo too. Could still cruise OK on the highway with no overdrive. Get the 4.56's or you'll end up kicking yourself later.
    '73 K5
    Chevy good...Ford bad
