What gears should I be running?
Discussion in 'The Garage' started by Mastiff, Aug 11, 2003.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I've got 35" tires on my truck. Originally, I had a TH700 trans with the great overdrive, and I put 4.56 gears in (replaced the factory 3.73's). Now I have a TH400, so I'm spinning over 3K RPM on the interstate with no overdrive.
    The gears are great for everything except cruising, but it really sucks for that. Should I go back to 3.73, or maybe split the difference with 4.11's? What RPM does a stock 350 like to cruise at anyway?
    BTW, since a gear swap is out of my league, what would a typical shop charge for labor?
    Thanks for any advice!
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    over 3000 rpm? what are you doing 75-80 mph? doing 65 you should be turning around 2800 rpm
  3. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Heres a good link to see the diference of gear selection and tire sizes.
    Geartable
    The 700R has a .70 overdrive and a lockup converter. The TH400 doesnt, therefore you are going to spin higher RPMs.
    To change ring & pinion in both front and rear, your probably looking in the $500-600ish range.
    Tha 350 runs fine in the 3000RPM range. Gas mileage may suck but you wont hurt the motor.
  4. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I'd say I hit 3K around 60 MPH. Maybe the tires aren't really 35", or the non-lockup trans is slipping a little. Either way, it seems like it's screaming. Maybe it's okay. The people who wrote the gear table seemd to think 3000+ is no biggie.
    I think the truck cruised around 1700 in factory configuration. /forums/images/graemlins/rolleyes.gif
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    do you have a tach or are you guessing?
  6. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I have a tach.
  7. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    Then your tires are short or your trans is slipping. 3000 RPM is fine but as you know the MPG will suck.
  8. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    More likely it's because I never changed my speedo gear, so my speed numbers are all indicated, not actual (or would that make it wrong the other way?). Who knows how accurate my sunpro tach is either.
    Anyway, I'm hearing that most people wouldn't sweat it too much. It's probably not worth the cash to redo the gears. If I ever replace my axles, I'll go at least to 4.10.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It's your speedo is messed up. Your tach is perfectly accurate.
  10. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    With no O/D I really like 4.56s and 35s. It was just costing me too much when I went from a 15 mile commute to a 90 mile commute. It was my DD for a few years before I changed jobs.
