What gears should i buy?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chvyblzr1977, May 8, 2002.
  1. chvyblzr1977
    chvyblzr1977 Registered Member
    Jul 18, 2001
    83
    Pissburgh,pa
    I have a 77 blazer 350 with 10 bolt in the front and 12 bolt and the back im currently am running 35 but plan to upgrade to 38's maybe 40's i was thinking about getting 4.11's what do you guys think.The shop said 600 to install it is that a fair price.
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    38's or 40's on 1/2 ton running gear isn't a very strong set up, but if that's what ya got, 4.56's would probably be best. Expect to be replacing parts.
  3. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    4.56s definitely. I run 4.56s with 35s and an AOD tranny. works great, even with using OD. If you want to go bigger than 35, you should definitely go 4.56. I wouldn't go any taller in a 10-bolt. The pinion gets to be too small. $600 installation is about fair. Around here, best I could find was about $250 an axle.
  4. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    i run 4.56 with my 35" ProComp MTs... and every time I climb a hill I am glad I have gears as low as I do. Thanks to having OD, I never run to high of RPMs on the freeway.... if you don't have OD, then a higher gear may be better...
    J
  5. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I would run 4.56's if I were you. I run them with 35's and I love them.
