What gears to run
Discussion in 'The Garage' started by k5blazerus, Jan 29, 2003.
  1. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    I have done a search and found nothing .
    I would like to know what gears I can run with this Combo.
    Right now I am running 36 sumpers, Th400, 208, and 4:10 gears. This Combo is not that bad. I am planning on going to 38.5 inch tires. What gears can I get away with and what gears would be best to run.I drive my tuck daily and mostly play on dirt trails, snow, mud and sand.
    Thanks Colin
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    4.10's are the good highway gear for your combo with no OD. If you do alot of highway I wouldn't go deeper then 4.56, but if you don't get alot of highway or you don't turn that many revs then 4.88's. If you are running a 1/2 or 3/4 ton front though and do decent wheeling the 4.88's are kinda small on the pinion diameter and you will be pushing the axle shafts and ujoint to the limit with 38's.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    colin my best friend had 38's and 4:56's on his bronco and he was always saying he wished he had went to 4:88's instead of 4:56's i am running 38's and sm465 np205 combo and have 4:10's right now but this month i will be going to 5:13's /forums/images/graemlins/shocked.gif but i also plan on 42's some day hopefully next year so i only want to re gear once lol
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Depends on what you do in the t-case department. Dual t-cases can let you keep the economical axle gearing, and still provide the gearing you need off road.
    Just have to decide if you like ORD's 2:1, and 4:1 or Klune's 2:1, 2.72:1 and 5.4:1. /forums/images/graemlins/grin.gif
  5. k5blazerus
    Apr 22, 2001
    654
    Bend, OR
    I probally will not go to a dual t-case. The only wheeling I do is snow, lots of mud, sand dirt trails. We have noting hard core in bend. I was leaning towards the 4:88 if I go to 39.5 tires.
    By the way HOSSBABY50 I have I dana 60 in front now. Witch I need to go test out.
