what gears to use?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigjblazer, May 11, 2002.
  1. bigjblazer
    bigjblazer Registered Member
    Apr 9, 2002
    89
    Atlanta, GA
    i got an 84 k-5 w/305. Im goin up to 37" SSR's, and i have 3.07gears now. What gears will i need to put in, for optimal performance?
  2. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    always depends on the type of wheeling... and what other gear reductions you have in your tranny/tcase... but all else being equal I'd go with 4.56 or 4.88.
    J
  3. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Do you have overdrive? If you do, 4.88's would be perfect. If not 4.56 will do fine. I have 4.56 with 35's and its great but i dont have OD so it kinda revs high on the freeway, thats alright though =)
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I have 37" SSRs and I run 4.10s because I have a th350.The RPMs arent to bad on the freeway,its not a dog off the line, and I can crawl ok in low range.
    If I had an overdrive trans I would have gone 4.56.
  5. bigjblazer
    Apr 9, 2002
    89
    Atlanta, GA
    i have the 700r4 with overdrive, and i will be runnin 37"ssr's. im thinkin 4.56, would that werk alrite?
  6. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    if u have OD... go with 4.88s... that way, when u upgrade tires to 38-40s... you'll still be a-ok. /forums/images/icons/laugh.gif
    J
