What gears with 36's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Jun 8, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    What gears with 36\'s
    What gears would everyone rocomend for 36" swampers? I will be doing just as much street ar i will be off road.
    Check out my 73 K5 http://members.theglobe.com/xnoahx/73k5.htm
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
  3. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Re: What gears with 36\'s
    4.56 would be good for both street and trail. You'll kick yourself later if you get 4.11's...unless you want to drive 90 down the highway for sustained periods of time...then the 4.11's would help you out.
    '73 K5
    Chevy good...Ford bad
  4. tRustyK5
    Jul 23, 2000
    36,168
    1,366
    E-town baby!
    Doesn't that tire size thing just burn ya Frank? The only tires I've found that are near to true for size is my 36" Swampers...more than half worn and they still measure at 35 1/4" tall.
    I run 3.73's with mine...its OK, but I have a 4 speed so I don't worry about burning up my trans. My cruise RPM is about 2500 at 70 MPH...
    Rene
  5. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I'm running 4.10's with 36's , mainly because thats what was in the axels when i swapped them, but if i had my choice i'd prefer a little lower gear, 4.56 or maybe even 4.88 if i had an overdrive. 4.10's will be ok but if you think you'll ever go bigger, or want it to jump better off the line, go lower.
    RaisedK5
    "Of all the things I've lost, I think I miss my mind the most!"
  6. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    Well, i live in southern cali so there will be a lot of highway driving going on to get the wheeling spots plus all the normal highway stuff i do just getting around town. i think ill try the 4.11's. That should be better for the highway right?
  7. tRustyK5
    Jul 23, 2000
    36,168
    1,366
    E-town baby!
    I'd stay with 4.11's if you do a lot of highway and 4.56 if yer mostly in town. I'm eventually going to swap to 4.56's but I plan on 38's as well.
    Rene
  8. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
