what gears ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by riz, Feb 11, 2001.
  1. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Is there anywhere in the VIN # that's tells what gears I have ? Is there anywhere else I can find out ? What is the best way to figure out what they are ? I'm moving up to 35's from 33's this spring and I want to be prepared for any changes I may need.
    <font color=purple>L8r,
    .Riz.<font color=purple>
  2. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    Mr. Pig says look on your glove box option sticker. i think Pudding boy agrees.
    --matt
    <A target="_blank" HREF=http://www.geocities.com/shaggyk5>http://www.geocities.com/shaggyk5</A>[​IMG]
  3. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple>What if I don't have one in there ? I may, but I don't remember seeing one.</font color=purple>
  4. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple>Can anybody break down my VIN # for me............It's VIN # 1G8EK18COCF133521</font color=purple>
  5. cp87jimmy
    cp87jimmy Registered Member
    99
    Frisco,TX
    Built in U.S, 6001-7000 GVWR Rangen Brake System,4WD,1/2 ton, Utility,6.2L V8 diesel,1982,Flint, Mich.
    GO STARS !!!!
    <A target="_blank" HREF=http://www.cp87jimmy.ck5.com>http://www.cp87jimmy.ck5.com</A>
  6. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Where did you find the info ? Is there a web site to go to ?
    How about VIN # 166375S223955 ?
    Thanks !
  7. cp87jimmy
    99
    Frisco,TX
    What is that one off of? I got the one for your first vin number out of my LMC catalog.hehe Pretty resourceful huh?
    Chris
    GO STARS !!!!
  8. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> It's for my 1965 Impala.</font color=purple>
  9. cp87jimmy
    99
    Frisco,TX
    Here you go.....V.I.N. PLATE FOR 1965 - 1971 MODELS
    1st digit - Division -
    1 = Chevrolet
    2nd & 3rd digits - Series -
    53 = Biscayne L6
    54 = Biscayne V8
    55 = Bel Air L6
    56 = Bel Air V8
    63 = Impala L6
    64 = Impala V8
    65 = Impala SS L6 (1965)
    66 = Impala SS V8 (1965)
    66 = Caprice V8 (1966-71)
    67 = Impala SS L6 (1966-67)
    68 = Impala SS V8 (1966-67)
    4th & 5th digits - Body style -
    11 = 2-door sedan
    35 = 4-door station wagon, 2-seat (1965-68 models)
    36 = 4-door station wagon, 2-seat (1969-71 models)
    37 = 2-door Sport Coupe (1965-66 Impala & SS)
    37 = 2-door coupe (1969-70 Impala)
    39 = 4-door Sport Sedan )
    45 = 4-door station wagon, 3-seat (1965-68 models)
    46 = 4-door station wagon, 3-seat (1969-71 models)
    47= 2-door coupe (1966-71 Caprice, 1968-71 Impala Custom)
    57 = 2-door coupe (1971 Impala)
    67 = 2-door convertible
    69 = 4-door sedan
    87 = 2-door Sport Coupe (fastback) (1967-68 Impala & SS)
    6th digit - Model year -
    5 = 1965
    6 = 1966
    7 = 1967
    8 = 1968
    9 = 1969
    0 = 1970
    1 = 1971 7th digit - Assembly plant -
    A = Atlanta, GA
    B = Baltimore, MD
    C = Southgate, CA
    F = Flint, MI
    G = Framingham, MA
    J = Janesville, WI
    K = Kansas City, MO
    L = Los Angeles, CA
    N = Norwood, OH
    P = Pontiac, MI
    R = Arlington, TX
    S = St. Louis, MO
    T = Tarrytown, NY
    U = Lordstown, OH
    W = Willow Run, MI
    Y = Wilmington, DE
    Z = Fremont, CA
    1 = Oshawa, ON Canada
    2 = St. Therese, QB Canada
    Last 6 digits - Production sequence starting at 100001 at all plants.
    GO STARS !!!!
  10. cp87jimmy
    99
    Frisco,TX
    Now, release puddin boy to me and nobody gets hurt!
    GO STARS !!!!
  11. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Back to top</font color=purple>
  12. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Its probably not the answer you want to hear, but i think you should just pull off the diff cover. Think of it as maintenance, you'll get to change the cruddy gear oil in there, clean it out some with brake clean, and find out your ratio for certain.
    Every diff I've had the cover off of had numbers stamped on the edge of the ring gear, on my 14 the numbers are 41:11. Thats ring gear teeth to pinion teeth and works out to 3.73's.
    It not a time consuming job, just one that gets overlooked often anyways. You might find a code from the glovebox but that isn't a guaratee that someone hasn't swapped in something or changed ratio's, or even glove box doors.
    Rene
  13. mudpuppy89k5
    mudpuppy89k5 Registered Member
    Nov 3, 2000
    44
    Marietta, Ga
    Try rotating a rear tire exactly one revolution. As you do so, count the number of times the drive shaft rotates. If the drive shaft turns just over 4 revolutions, it would be a 4.11, about 3 3/4 would be a 3.73, about 3 1/2 would be 3.42, etc.
    John Perry
    http://www.mudpuppy.coloradok5.com/
  14. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Thanks guys, I'm just trying to find the easiest way right now, I don't want to spend any more time out in the cold than I have to here in 'Scony.</font color=purple>
  15. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Ok Riz... here is a pretty easy way to go... look in the glove box for a sticker that lists the code options for the truck... if there isn't one there then you'll have to crawl under the truck and get the code off the axle... should be on the pass. side circular portion of the axle. Then you can go to this page... It has all the code options for GM listed. Didn't look but probably has 3.42's if it is eighties... seventies would most likely be 3.73... also could have slug 3.08's like mine... soon to chage though!
    1987 Chevy K5 Blazer- 350 TBI
