What gears?
Discussion in 'OffRoad Design' started by chevys, Jul 12, 2006.
  1. chevys
    chevys Registered Member
    Jul 9, 2006
    6
    harrisonburg va
    I know ya'll have heard this question thousands of times but i havent found the answer im looking for yet. I got an '86 Silverado long bed thats stock right now. In the near future its getting a 400 small block and a rebuilt tranny (TH350, the one in it only has 1st gear. While out of commision I'm putting 4 inches under it and 33" TSL's and have been wondering bout my gears. I did the calculator thing on 4wheelparts.com and they suggested 4.10's, what do you guys think? Its a semi daily driver and will see 60-65 often but nothin over that.
  2. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    post this in the garage you'll get more help there :waytogo:
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    IMHO running 33's and 4.10's with a TH350 is the way to go, any more gear than that and it won't be very freeway friendly.
  4. HeavyChevySC
    HeavyChevySC Registered Member
    Oct 19, 2006
    5
    Jackson SC
    4:10 will be perfect. Thats what I've been running for over a year now.
  5. chevys
    Jul 9, 2006
    6
    harrisonburg va
    Plans have changed, tires are going up 2 inches to 35's and the transmission will be a Turbo 400, 4.10's should still be ok shouldn't they?
  6. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah id stick with 4.10's if you're gonna be on the highway.
  7. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    4.10's and 35's will be good for all around use, and keep the RPM down on the highway.
  8. chevys
    Jul 9, 2006
    6
    harrisonburg va
    Thats what I wanted to hear, thanks fellas
  9. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,229
    485
    New Hampshire
    Yup thats what i run 35s and 4.10s but with the sm465. Its a great combo, and I can still go 80mph plus without red lining. :wink1:
  10. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    As long as your not towing heavy loads over big hills you should be ok.
  11. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Sounds like all good advice, one thing to watch is future plans and carrier splits, I'd hate to have you spend cash on a locker for a 4.10 carrier and want to go to 4.56's later but need a new locker.
    Offroad gearing is going to be hurting but still usable so the next gearing upgrade should be a Doubler or lower t-case gears. That way you keep the cheap TH350 and 4.10's for the highway and get good offroad gearing. That's a pretty common and effective recipe so you're going down the right track.
  12. chevys
    Jul 9, 2006
    6
    harrisonburg va
    I was thinking bout re gearing the t-case, I've go 2 NP 208's, I know the 203's and 205's are stronger but can I beef up the 208 and make it just as strong?
  13. kennyw
    Jun 9, 2002
    13,223
    94
    Not a chance... however there are options for keeping the NP208 and adding an extra gear box with either the KluneV or some based on the NP241 gear box. None of them are cheap.
