What gears?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by big pappa b, Jan 7, 2003.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I just bought an 80 Blazer 4x4 with a 6 cyl and 3 speed manual trans. Any ideas what gears the factory would put in the front/rear axles?
    /forums/images/graemlins/confused.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> 4.10s are highly likely. There should be a tag under one of the diff cover bolts that will tell you, unless someone removed it. There's some other ways to tell, but this is the easiest. </font color>
  3. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    Also I have seen in an '85 in the glove box listed the gear ratio in the options list.
  4. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    if you cannot find it- jack the rear up. put a mark on the tire and line something up with it. trn the yoke and count the number of rotations before the mark on the tire lines up with what you lined up with it. if it's a little over 4, then it's probably 4.10, if it's 4 1/2 then 4.56, almost 5, then 4.88. . . and so on.
  5. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Those would be 2 other ways to tell, but like I said, the tag is the easiest. /forums/images/graemlins/thumb.gif The last way to find out is by pulling the diff cover and checking the stamp on the edge of the ring gear. This, for obvious reasons, is also the most accurate way. /forums/images/graemlins/grin.gif </font color>
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    The 6 cyl usually meant lower gears. Not a bad deal at all.
  7. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Get the VIN number off the truck and call your local Chevy dealership parts dept. and tell them the number and they will be able to tell you what ratio you have in that truck, as long as it is the orginial one /forums/images/graemlins/thumb.gif
    Eric /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  8. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Actually when you do the rotating tire test, you have to double the number you get since the one wheel turning will ride the pinion gears at half the speed. So one turn of the wheel will give you almost 2 turns of the driveshaft for 3.73, a little more than 2 fr the 4.11, 2 1/4 turn for 4.56
    I believe these will be the only options that came stock with a six cylinder.
  9. dyeager535
    26,979
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    dyeager, wow ! nice collection of brochures ! /forums/images/graemlins/laugh.gif!
