What gears??
Discussion in 'The Garage' started by Tshane, Feb 4, 2003.
  1. Tshane
    Tshane 1/2 ton status
    Nov 26, 2002
    144
    Peoria, Illinois
    What gears would u recommend for a 383 with a 700r running 35's??? i can't decide 4:10 or 4:56.....i'm starting to lean toward 4:56 but i was hoping someone could give me there opinion on the matter /forums/images/graemlins/grin.gif
    <FORM METHOD=POST ACTION="http://coloradok5.com/forums/dopoll.php"><INPUT TYPE=HIDDEN NAME="pollname" VALUE="1044415202Tshane">
    4:56 vs 4:10
    <input type="radio" name="option" value="1" />4:10
    <input type="radio" name="option" value="2" />4:56
    <INPUT TYPE=Submit NAME=Submit VALUE="Submit vote" class="buttons"></form>
    Thanks again /forums/images/graemlins/truck.gif
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    What do you use the truck for? DO you ever plan to upgrade to larger tires? What is the ACTUAL tire height measurement of the tires you are running while on your rig?
  3. Tshane
    Nov 26, 2002
    144
    Peoria, Illinois
    Its going to be used for a vechile to get me to work or school and Wheeling. Its only going to be used for mud no rocks. I dont not plan to go bigger then 35's and the tires r 35 x 12.5
  4. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    4.10s might be better for higher speed driving,but,4.56 and OD should let you run 60-70 MPH with no probs. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
  5. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    The tires are sized at 35, but more than likely they are around 34" actually or even shorter, depending on manufacturer. However, for your usage, I don't think that is much of an issue. I would go with the 4.56's for the best all-around performance. 4.56's will give you good acceleration with the low first of the 700, but the overdrive will keep the highway RPM's manageable. Good all-around combo with a 700, 35's, and 4.56's for your application. /forums/images/graemlins/thumb.gif
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I run 60-70 no problem with 4.56's, 32's (actually about 30.5-31") and OD. I really like the 4.56's. I will like them a little more when I get some 35's, but it is still ok with 32's.
  7. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I run 4.56's and 36's with a 700r4. I dont have a tach, but I run about 70 on the highway with no problems. I would definatenly recommend the 4.56's.
  8. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,139
    14
    Bangor,Pa
    id say with an OD u would want to run 4.56 to 1 gears.im going 4.10 with 35's but i have no overdrive so it will give me a better highway final ratio.
