What GM cars came with big blocks?
Discussion in 'The Garage' started by jp0863, Feb 14, 2005.
  1. jp0863
    jp0863 1/2 ton status Premium Member
    Aug 15, 2004
    566
    clovis, ca
    i have a friend building a camaro that wants a 454 from a car. i guess the heads are a little different on the cars than the truck. anyone know what had a big block? something that might be found at a wrecking yard.
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I'm guessing he wants rectangular port heads? Really, if it was me I would just get any block and use aftermarket heads. I am not real sure about a 454 in GM cars but there were lots of 396 options in the 60's SS models IIRC. There is always the LS6 454 but those are hard to find.
  3. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    70-74 chevelles, monte carlos, impalas, and vettes. The oval ports are the same castings between cars and pick ups of thet era, the peanut ports first showed up in 75 trucks.
  4. ssls6
    ssls6 Registered Member
    Jan 5, 2005
    86
    Dallas, TX
    Full and mid-sized cars (A bodies) from 66 to 75 or so. You'll need to learn how to recognize heads from the casting numbers or stamped engine codes.
  5. Lonnie P
    Lonnie P Registered Member
    Feb 7, 2005
    28
    Pittsburgh, PA
    The 454 was first introduced in 1970. 74 or 75 was the last year in cars.
    After that only trucks had them. They varied in HP greatly over the years.
    Many of the High Perf versions bring good money to collectors. If planning to build one, it is a often a very good deal to get a crate motor in the long run.
    '70 was the best performance (LS6 Chevelle 450hp), but the best running ones will not run on todays fuel. As they got newer, the performance dropped (and compression), but regular fuel was a possibility.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Go pull a engine from a station wagon , one that has been heat cycled on and off many times from trips doing mommy's errands . Then buy aftermarket heads :grin:
  7. zx672
    zx672 Registered Member
    Mar 2, 2004
    48
    Olney, MD
    My dad has an old school Cadillac Eldorado....I think 1972 or 76...can't remember. It has a 502 in it w/front wheel drive :blush: and it moves that big tub of steel just fine!:D
  8. JIMMY76
    JIMMY76 1/2 ton status
    Dec 28, 2004
    209
    HAUGHTON,LA
    Find An Old Caddy They Came With Bb
  9. WantedaDodge
    WantedaDodge 1/2 ton status
    Dec 16, 2004
    282
    Eugene, OR
    will a cad 500 bolt right in where a 350 was? I've always wanted a 500 cad motor in a truck. My blazer may just be a good excuse. The performance parts are spendy, but you don't hardly need anything other then an upgraded intake!
  10. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Is this for the street?A good set of Merlin or other aftermarket heads is the way to go.Most of the aftermarket Brands you can buy bolt right on out of the box............................
  11. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    you need an adapter, or a BOP transmission.
  12. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I have a factory bore ls6 454, factory heads, everything, pm me for details if you friend is interested.:grin:
  13. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You have a LS6 motor ? As in 1970 Chevelle ?
  14. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    yup, sitting, it may be for the build for the 496, if I ever buy the kit to do it,
    I thought we already talked about this last month? I think yours or my memory is fading:D
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Why would anybody want rectangular port heads to drive on the street?:confused:
