What happen to my ring gear??
Discussion in 'The Garage' started by 84CUCV, Jan 12, 2007.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    What would cause this to happen? shock load? if it matters its a 83 with 350 3/4 ton and 35" boggers. thanks guys
  2. iwaxmyjimmy
    iwaxmyjimmy College web wheeler Premium Member
    Nov 3, 2006
    2,802
    34
    Greenville NC
    the ring gear teeth were cracked and it brokeded:D and is that mud in the gear lube?
  3. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    usually it's deflection that causes that kinda thing. i suppose them not being set up right could do the same thing, but i dont really have experience with that. but yeah you more or less took the diff to its limits. is it stock? 10 bolt front right? and like iwaxmyjimmy pointed out, it's possible that your gear mud contributed to it as well hehe.
    :wink1:
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    its a 8lug 10b. guess my friend needs a 10b crap..... Not sure what it is no oil come out at all when i poped the cover
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    damn i didnt notice that its on almost every tooth, yikes. no oil coming out when u pop the cover is not a good sign
  6. iwaxmyjimmy
    Nov 3, 2006
    2,802
    34
    Greenville NC
    tell him to get the axle acid tanked and rebuild it completely(new gears and carrier) only way to get all that gunk out.
  7. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    or buy a d60 for the same price;)
  8. iwaxmyjimmy
    Nov 3, 2006
    2,802
    34
    Greenville NC
    thats what i would do but he said something about needing another 10 bolt
  9. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    The oil just looks nasty. I would guess that contributed.
    I had a 12b rear do something similar. My guess is small amounts of contaminant got smashed between ring and pinion creating a stress point creating a crack and then failure.
    ...after close look all the teeth are broken the same, like the stress was on the end of each, like maybe not set up right, or perhaps due to lack of oil, wear caused the backlash to change.... or something.
  10. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    just looked at it a again. the pinon bearing is gone, nothing left to it at all. i am sure that helped also, i dont think my friend wants to spend the cash on a 60.
  11. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    The pinion bearing probably crapped out and allowed the pinion to deflect, causing the ring gear failure. FWIW, I stipped the teeth completely off the ring gear and pinion on a REAR 10b- open on 285's. With a 305.
  12. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    damn, what does FWIW mean?
  13. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    for what it's worth.
  14. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    :haha: Not trying to be an asshat, but the stereo is too loud.
  15. sweetk30
    Nov 1, 2004
    25,550
    543
    horseheads , ny 14845
    tell your friend thay are mud trucks not water trucks also. thats water mixed in with the diff lube. :eek1: :rolleyes:
  16. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    ok thanks guys
  17. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    if the pinion is salvagable I have a brand new ring gear unopened in its plastic wrap. I also have the pinion but the threads on the end are slightly buggared. I was thinking I'd just scrap it because what good is a ring gear without a pinion?
  18. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    btw.... 35" boggers will do that to a 10b lol
  19. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Can't do that. Gears are machines as a set. Mixing them would just add to the trouble.
  20. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    screw it maybe i can find one more 60. thanks
