What Happened?
Discussion in 'Audio' started by jimmyjack, Jul 24, 2001.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I was driving my wifes car today and was setting stations on the 2nd FM presets, all of a sudden it went DEAD! I pulled the deck (KENWOOD KCD 1011S), unplugged the harness (yes hers was nescessary) and it has power all the way up the back of the deck. The fuse on the back is intact. I dunno what the hell I did. Obviously internal, any ideas? And of course it's past its warranty date, no extra warranties either. Any ideas on cost to repair? AAAAAAARGH we're taking this car to Vegas in a few days!
    "My blazer may be slow, but it goes faster at higher speeds"
    <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  2. speed_deed
    speed_deed 1/2 ton status
    Jun 15, 2001
    947
    Valley Center KS
    2 WORDS. YOUR ****E.D
    1985 k-5 gmc jimmy 4x4 sierra classic. 1970 cuda 440 6 pack executive edition steering column shift.
  3. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    I knew that!!! Even without a cruddy stereo I'm already traveling that road. I was thinking the power unit. I have another kenwood cd laying in a box around I was going to swap some parts see what would happen. Maybe an internal fuse even.
    Jim
  4. speed_deed
    Jun 15, 2001
    947
    Valley Center KS
    LOL....... MY VERDICT STANDS!!!
  5. Prembird
    Prembird 1/2 ton status
    May 15, 2001
    811
    kc, mo.
    check the fuse in the fuse block before you go playin with internal parts...
    Prembird
    [​IMG] <font color=blue> If it aint</font color=blue><font color=red> LOUD </font color=red><font color=blue> Then turn it </font color=blue><font color=red> UP</font color=red> [​IMG]
  6. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    When you checked both power wires behind the deck did you also check for continuity on the ground wire? If thats not it, then yea, your radio is probably toast.
    '73 K5
    Chevy good...Ford bad
  7. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Yep i checked BOTH hot wires and the ground for continuity. Every fuse on the car is good! But why would pushing a preset button fry the thing? Oh and check this out! I turned on the TV last night and it took a [censored] too!!!!!! I realize I work in the electric construction biz but c'mon! It's only 13,800 volts phase to phase. That oughta wear off by the time I get home.
    Jim
  8. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    You know.....as of tomorrow morning, it will be exactly 13 days since Friday the 13th!!!!
    I would not leave the house if I were you.....and don't TOUCH anything!
    -Greg72
  9. Prembird
    May 15, 2001
    811
    kc, mo.
    i agree with greg72 on this one... just sit down and dont touch, look, or think about anything.. your screwed...
    and stay away from my electorics... hehehehehehe
    Prembird
  10. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    NO DOWT !!!
    Jim
  11. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Time for a knew deck.......
    C'moe
    <font color=black>the blazer is "Back in Black"
  12. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    I had this problem with my old kenwood tape deck... just went dead, so, uppon opening it, I found that one of the boards copper paths had blown out ( the main power lead) so, i soldered a wire in place to close the gap. apparently one of the speaker-out wires had hit bare sheetmetal, and overloaded the main power circuit before it could blow the fuse. I fixed it, wrapped more electric tape around the speakerwires, and havn't had a problem since then.
    good luck tho,
    -Rich
    ph34r m3!
    1337 TruXoR
  13. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Cool I havent lookied into it yet but I will Thanks for the heads up!
    Jim
  14. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    Does that model deck have a removable face? If so, remove it, clean the contacts with alcohol, and re-install it. I'm thinking that since you were punching buttons on the face when it quit, it's remotely possible you moved the face and lost connection with one of the contacts. It's a long shot, but worth a try. Good Luck
    '89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".
  15. Prembird
    May 15, 2001
    811
    kc, mo.
    good point ganfolf... I forgot about that one..
    Prembird
