What happened ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SWAMPRNR, Dec 28, 2002.
  1. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    Put manual hubs on 77 pick with a 203t/case. Now if the locks are not locked in the truck will not move.
    Never messed with a 203 is this normal ?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    the case needs to converted to a part time case. the 203 is a full time case and has a differential built into it. Kind of like jacking up one tire on an open differential.
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    The 203 should still push the truck when in the 4 HILOC and 4 LOWLOCK positons but in 4HI and 4LOW the T-case will only spin the front shaft if it has not been converted to part time.
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I'm guessing he didnt try this. /forums/images/graemlins/grin.gif
  5. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    It happens to the best of us sometimes... usually after a long day of installing gear on a buddies unfamiliar truck. You can only hope you figure it out before you start taking it all apart again looking for a non existant problem. I hate it when that happens!
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I ussually end up taking it all apart anyway because I dipped it up somewhere. /forums/images/graemlins/grin.gif
  7. SWAMPRNR
    Apr 7, 2001
    296
    Temple Texas
    That solves that problem. Never used 203 before. Thanks
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    You bet. Good luck with it. /forums/images/graemlins/thumb.gif
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Go to the main CK5 page, then scroll down to the tech article on Mile Marker conversion kits. It explains what happens in a 203 and how to convert it to part time. /forums/images/graemlins/cool.gif
  10. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    running a 203 in hi loc w/manual hubs w/o a kit will kill it.must convert to part time.better yet,if you can,swap it for a 205.its kind of a boat anchor.
  11. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    How,why? Never heard of it being a 'prob. Done it for up to two months at a time w/o anything going wrong.
  12. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    i dont remember exactly why,i read about it in 4wheeler,or 4wheel and off road.cant remember.they will wear inside and develop a clunk when you get on or off the gas,and eventually come apart.a actually bought a truck w/a 203 that had the front driveshaft removed.it had the clunk in it,but i didnt have it long enough to deal with it.trust me though,there is a conversion kit for a reason.if it wasnt needed,it would just be a set of hubs.
  13. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    The big plus to the kit is it saves gas and saves the front shaft ware. I don't see how spinning an unloaded shaft will cause damage. If you install the kit and don't use 4WD monthly it can cause damage due to oiling problems. The kit instructions even tell you this. Mags want to keep advertisers happy.
  14. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    i dont know,ive heard several times that you must convert to prevent damage.id do some research to make sure if i were you,but the 203 is a heavy high geared p.o.s anyway.
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Another newbie talking $hit.....
    Now I understand why pirate eats their young.
  16. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    newbie.ok,whatever.you have been around so much longer ,you are the king.and as for talking $hit,i tried to help,and ill bet this weeks check im on target about the conversion.my opinion on the 203 is my opinion(and that of most of the free world).they are good for the doubler,but we dont need 4:1 in florida to run trails or mud.
  17. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Your most definately entitled to your opinion but I disagree with you that an np203 is a piece of junk. The np203 is not a bad unit to have at all and can take just about as much abuse with its chain drive as the more popular np205 all gear unit. It has a lower ratio than the np205 while offering all wheel drive capabilities or part time capabilities with a kit. Your comment on the doubler usage is just another flexibility it provides. On top of that you get a cast iron case with fixed yolks. Given the choice I'd probably go with an np205 but the np203 comes in a close second above most every other offered in the 73-91 chevy trucks. Running your np203 in the hi loc position accomplishes the same thing the part time kit does and doesn't cause any long term wear when the front hubs are unlocked. What you don't get running this way is the capability to switch from 4wd (low or high) to 2wd (low or high) from the shifter as opposed locking and unlocking the hubs. Some part time kits for the np203 are nothing more than clips that keep the internal front to rear differential gears from opperating out of the LOC positions as opposed to eliminating them all together.
    Model --- Mode --- Drive --- Low Ratio
    NP203 --- Full-Time --- Chain Drive --- 2.00:1
    NP205 --- Part-Time --- Gear Drive --- 1.96:1
    NP207 --- Part-Time --- Chain Drive --- 2.61:1
    NP208 --- Part-Time --- Chain Drive --- 2.61:1
    NP219 --- Part-time/Full-Time --- Chain Drive --- 2.61:1
    NP228 --- Part-Time --- Chain Drive --- 2.62:1
    NP229 --- Part-Time/Full-Time --- Chain Drive --- 2.62:1
    NP231 --- Part-Time --- Chain Drive --- 2.72:1
    NP241 --- Part-Time --- Chain Drive --- 2.72:1
    NP242 --- Part-Time/Full-Time --- Chain Drive --- 2.72:1
    BW1305 --- Full-Time --- Chain Drive --- 2.57:1
    BW1345 --- Part-Time --- Chain Drive --- 2.74:1
    BW1350 --- Part-Time --- Chain Drive --- 2.48:1
    BW1354 --- Part-Time --- Chain Drive --- 2.48:1
    BW1356 --- Part-Time --- Chain Drive --- 2.69:1
    BW1370 --- Part-Time --- Chain Drive --- 2.69:1
    BW4404 --- All-Wheel Drive --- Chain Drive --- ?
    BW4405 --- ? --- Chain Drive --- ?
    Dana 18 --- Part-Time --- Gear Drive --- 2.46:1
    Dana 20 --- Part-Time --- Gear Drive --- 2.46:1
    Dana 24 --- Part-Time --- Gear Drive --- 1.86:1
    Dana 300 --- Part-Time --- Gear Drive --- 2.62:1
    Spicer 20 --- Part-Time --- Gear Drive --- 2.03:1
  18. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    OK, so no info to back up the claim? I "hear" stuff all the time but I am not going to believe it blindly.
  19. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    nice rebuttal mike /forums/images/graemlins/thumb.gif
    as many 203's are out there in old farm trucks that the help drives and abuses, i would think they are some pretty stout cases, i too, have heard of many people taking the full time hubs off and just replacing them with part time without the kit, and since they are so plentiful you can pick one up (not literally, they are heavy) for just about free /forums/images/graemlins/cool.gif
    maybe not the best, but not a p.o.s. in my book
  20. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I would rather have the 203 than the 208. I kept breaking those 208's. My 205 has held up fine though. /forums/images/graemlins/smile.gif
