What happens to my $150 inline pump when i hit water?
Discussion in 'The Garage' started by dirtwarrior17, Apr 27, 2005.
  1. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    Was under the blazer looking for bolts and i realized my fuel pump is now level with the frame and naked to muddy water...do these things break down when you submerge em?
  2. Ryan B.
    Jul 18, 2001
    5,693
    CA
    well, when i was watching a TTC video and a guy with tpi on his jeep hit one of the mud/water holes in the tank trap, his fuel pump died..
    i was thinking its probably a good idea to get a spare and carry that with me. :cool1:
  3. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    What are you running for a fuel pump?
    I run a Walbro EFI pump mounted on my frame rail and it doesn't mind being submerged. It's a completely sealed pump that can be mounted in the fuel tank though.
    I keep a spare Mallory EFI pump with me. I origionally ran this pump, but switched to the Walbro because it does not seal well against mud/water.
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I havent had any problems with my edelbrock pump being underwater.......yet....
  5. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    I also running the edelbrock pump with the proflow kit and have not had any problems with it being under water. It spent about two hours under one night and it works great.
  6. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I have a holley that is 3 or 4 years old now that has been under several times
    with noproblems. I did not do anything to it just made a place to put it and hooked it up.
  7. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Put it in the cab with you right next to the seat like I did. :surepal:
  8. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    Its an accel.... the smaller one in jegs... rated at 45 psi...
    I don't want to have to find out the hard way. Seems like no water should be able to get in if no fuel is able to get out. :confused:
  9. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    I ran a Holley "blue" pump for about 5 years with no problems. I had it mounted in the lower, straight section of frame and never had any problems running the swamps here.
  10. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
  11. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    if your connections are soldered and heatshrinked like they should be there should be no problem at all.
