What happens when you go grinder mad? 13 bolt pics
Discussion in 'The Garage' started by sled_dog, Nov 9, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    finally got picture of the 13 bolt...
  2. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Good luck getting that thing to not leak... /forums/images/graemlins/eek.gif
    Rene
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I second the good luck.....all i did when I ground my 14FF is I just ground the lip off and rounded it off nice and smooth /forums/images/graemlins/thumb.gif
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah thats why I bought the Bluetorch Fabworks cover wtih the 3/8" thick flange.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I got bored a few days and kept going and going then when I broke into the bolt are I said screw it and kept going.
  6. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I wonder if it is possible to weld in some extra metal on the inside of the diff to create more sealing area? WOuld probably be hard and complicated but if it worked it would be sweet.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    considered stuff like this before, welding cast iron = no I'm not gonna. I am gonna make a skid plate so rocks aren't bashing that thing since I just went too far
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    silicone caulking should do the trick, especially with the the modification being at 12 o clock of the diff housing, i think youll be fine,
  9. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    The diff is pictured upside down...the bottom has been shaved for better ground clearance.
    Rene
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    quite correct. I am going to use plenty of RTV and my Bluetorch cover and just hope it works out.
  11. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    If all else fails, start looking for a new housing /forums/images/graemlins/crazy.gif
  12. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I meant welding it in general, not necessarily for you specifically. I also was thinking about the strength issues of welding outside and inside of the diff. On the inside there would be no bashing or hitting of the welded on piece, its only purpose would be to provide surface area for sealing.
    So basically I am thinking out loud on this one, is it possible to weld inside to create more surface area for sealing but not to add any structural integrity or anything like that /forums/images/graemlins/thinking.gif Because if you could it would make it possible to trim more off a 14 bolt without sacrificing sealing ability.
  13. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    You can weld on the housing, as long as you know what you are doing.
    These are pics of 1TONTJ on Pirate
    OOOOOOHHHHHHH
    AAAAAAAHHHHHHHH
    The ring gear in those pics has been turned down.I feel this is a bit extreme. You can easily get 1.5" out of it with not getting into the ring gear.
    This what I am doing, short of turning the ring gear, although I am going to truss the tubes over the top just cuz a K5 is heavier than a jeep.Tig welding it would probably be best. I know you are'nt going this far, but I thought I would point it out so you know people do weld on them. /forums/images/graemlins/thumb.gif
  14. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Holy Crap Batman! That's some ground clearencing! I'm impressed! What did he use to weld that with!? Very Curious! /forums/images/graemlins/thinking.gif
  15. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    It's Tig welded /forums/images/graemlins/thumb.gif
  16. Batmanjr
    Mar 23, 2001
    1,537
    How does he plan on sealing that 12 inches of boltless terrain? Seams like a good 'ol peel and eat to me..... /forums/images/graemlins/thinking.gif
  17. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    This is apic of his first cover. This is normally what I see.
    Being that it is 1/2 on the bottom you could easily add two 1/4x20 bolt to help seal.
  18. Batmanjr
    Mar 23, 2001
    1,537
    Nice cover... One thing I don't understand is if you're going to go through that kind of trouble to make such a thing... Why not redo the whole cover... What if you hit the edge of a rock on the side of that ring gear protector... You'll puncture that cover quicker than crap and still be out of service... I never did understand that ring gaurd mentallity... It looks like some great work and alot of forthought.... Very interesting and possibly on the future list of mods! Only thing I would change is the effort put into the cover! /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  19. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,612
    561
    Wasilla AK,
    it's not a ring gear guard they add that to clear the ring gear with 5.13 gears ( 4.88's also ???) the ring gear rubs the diff coverthey section the cover and weld in that plate to give it the extra clearance
  20. Batmanjr
    Mar 23, 2001
    1,537
    Personally, I think you're wrong.... You might be right, but I have 5:13s in my 14FF and have a stock cover and NOTHING rubs! The ring gears don't get any larger in diameter.... The r&p only changes how many teeth, not diameter... In other words, Hypathetically, a set of 2:73 don't have a diameter any smaller than a set of 5:13s.... /forums/images/graemlins/deal.gif
