What has changed in DANA 60s over the years....
Discussion in 'The Garage' started by 84CUCV, Jun 9, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Just wondering if one better then the other. thanks
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    As far as GM versions go The first year or two had a thicker passenger side top spring cap/cover that was cast iron instead of stamped steel - other than that the "fat" axles started in around 1979 and continued until the end in 1991 . Basically if you address the axle thickness issue all GM versions are created equal .
    Tom
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I think the knuckles on the newer ones have a higher tierod mounting location
    I know that my dodge version does
    also the axles can be neck down in the old ones vs fat in the new IIRC
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    1985 and up the shafts didnt neck down at all.
    Grant
  5. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Ok so 85 and up are the best. So the 79 60 is a little weaker? Is there a big differnce?
    mike
  6. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    If you upgrade to 35 spline stubs with flages, and run a 84 and prior Dana 60 the next thing to break will probably be your innershaft. If you have the 85 and up shafts and 35 spline outers, the next thing to break will be your u joints.
    Either way 'sumthin' is breakin' but id MUCH rather not break an inner shaft and but a worse shock load on my detroit.
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK thanks for the information guys.
