What has to come off when changing cams?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, Aug 22, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    Since I'm gonna have to change my timing cover, I figure it's now or never with the cam. Besides the obvious stuff that has to come off to get the timing cover off, what parts will absolutely have to come off to change the cam? And are there any parts that alot of people take off, but don't necessarily have to come off? Thanks
  2. tipoil
    tipoil 1/2 ton status
    Jul 30, 2002
    222
    canada guebec
    distributor,intake,valve cover,lifter,pushrod i thing that about it
  3. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    That pretty much covers it, and of course the water pump. dont forget to have new intake gaskets on hand when you are doing it.
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Also change the timing chain and gears while you're there.
  5. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I just changed mine a few weeks ago, and this is all the stuff that had to come off of mine,
    Intake mainfold, and obviously everythng mounted to or thru the intake, ie carb, distributor, etc.
    valve covers, rocker arms
    oil pan
    Water pump, p/s pump, alt, smog pump
    balancer
    timing cover
    fuel pump
    now thats all just to get at the cam, to get it out i had to take off/out
    the radiator
    the a/c condensor, which required the removal of the grill
    the center grill support,
    and i think that was about it.
    it took me a couple days, but man it was well worth it. I had a flat lobe/destroyed lifter, but now she purrs like a kitten. /forums/images/icons/grin.gif /forums/images/icons/grin.gif
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    do you see any way of doing it without having to open the A/C system?
  7. JoseK5
    JoseK5 Registered Member
    Dec 12, 2001
    62
    Lebanon
    If you change cams often, you might want to consider upgrading your lifters to roller ones; this way the intake manifold stays in place. Plus; I think; you get an increase in power.
