What have I done? *Edit: NWF comes through again!*
Discussion in 'The Garage' started by pvfjr, Nov 10, 2006.
  1. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Hope I can get it together again. :yikes:
  2. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    BTW, does anyone have any brilliant insight as to a way to put the intermediate shaft back into my 205? Was a pain to take out, and with the shims, tight fitting tapered roller bearings and all, I'm skeptical about the reassembly. Gonna be tough.:crazy:
    One other question, this case will be off to my machinist to be bored out for the larger 32-spline bearing. I got the bearing and input shaft from NWF. Shouldn't they have included the snap ring that goes on the input shaft and retains the input bearing? I didn't get one... Is that something you can even get at a parts store?
  3. dabears73k5
    dabears73k5 Registered Member
    Jul 27, 2005
    52
    El Segundo, CA
    ah a np205. Mine went back together alot easier then it came apart. Remeber to put the shift rails back in the right order or ti will be a pain. Good luck man
  4. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Hmm, I was just thinking maybe I could tip the case up onto it's backside so I don't have to fight the gravity of the massive one piece intermediate gear. :thinking: That thing tried to take my fingers off. :doah:
  5. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    put it in the freezer the night before re-assembly...
  6. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Put what in the freezer?
  7. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    he wants u to put all u have on that bench into a freezer.. that way the parts shrink a lil and fit together better or well easier.
    WOO HOO 1000posts
  8. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    lol, the shaft you're worried about not fitting because its tight.,.. it will contract a little
  9. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    I could through the shaft in, would probably help those bearings slide onto it a little easier. Still gonna be hard to get everything to stay in the right spot. I managed to mangle a shim just taking it apart. Oh well, I've done more difficult things I suppose. Maybe it won't be as hard as I think. Just have to wait for the case to be bored.
  10. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,026
    854
    Pinckney, MI
    Yeah Shrinkage!!!
  11. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    So you're telling me that if I put my shaft in the freezer, there will be shrinkage? :yikes: :crazy: :p:
  12. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    so guys..:D
    what your all saying that if I put my shaft in the freezer it fits in the hole easier?
    interesting, might have to try that:crazy:
    edit..he beat me to it, lol
  13. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Anyone know anything about this?
  14. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Warning, these are professional drivers on a closed race course. Do not attempt this on public highways.:haha:
  15. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    hell you wanted help?? sorry i initiated the threadjack
  16. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Bring the shaft and bearing to a tranny shop and ask them if they have a snap ring that will work. IIRC one from a 208/241 will work.
  17. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    If you want fast shrinkage, just throw it in the pool. That always works for me! :laugh:
  18. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    yep, putting the shaft in the freezer will make the shaft shrink, and if possible put the bearing that goes on it in an oven that will cause expansion, but make sure you get bearing where it goes b4 everything cools or warms because it will be there.
    when i used to work in a machine shop and we rebuilt gear boxes, we had this tool that was a piece of square stock about an inch square that had a u shaped stand and the 1'' stock sat on top of the u....
    you picked up the piece of stock and slide it thru the bearing and replaced it on the stand, plug it in and turn it on and it became a electromag that vibrated and it would sit there and humm and it actually rotated the bearing, just because of the vibration i guess, but after about 20 min the bearing would be so hot you couldn't touch it, you had to use gloves and take it off slip it on the shaft to where it goes pretty quick, hold it til it cooled alittle and it would shrink down and stick itself on the shaft. i mean tight!! tighter than you could drive it on with a bfh and a bdp(bull dic punch), without the chance of harming the bearing.
    i have a toaster oven in my shop that i use to heat parts that are (i'm at a loss for words, i can't think what it is called, i know it starts with a c...and means its when two things are held together just because of tolerance. its a common term. compression fit, that don't sound right tho, please someone put it out there or it will bother me the rest of the night)
    but yea its physics, works on everything except water, which contracts as it cools also, but once it hits 34 degrees it starts expanding, where as all other matter as it gets colder the molecules get closer together, and as things heat up the molecules become further apart!
    man what is the word....contact fit....compression fit, maybe, sum1 please straighten my still slightly altered brain, constriction fit....dam it man, this is why you don't drink while working on your rig, wait til afterwards!!
  19. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Don't know about the "a c", but there's such a thing as "interference fit" on the order in fractions of a thousandth, depending on materials and the kind of service required. :D
  20. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
    that'll work, but there is another word that means the same thing basicly that starts witt a "C", but it not that important, its the same as interference fit,didn't think of that, thanks
