What have y'all done about your parking brake cables?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76_Cheyenne, Aug 12, 2002.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    What have y\'all done about your parking brake cables?
    After I lifted my truck 6" and lowered my t-case, the parking brake cable that runs under the t-case is in the way. it has even started to wear a groove into the t-case. What have you guys done in order to keep your parking brake?
  2. amm888
    amm888 1/2 ton status
    Jul 20, 2002
    309
    Woodland Hills, CA
    Re: What have y\'all done about your parking brake cables?
    my truck's got the same problem, groove and all. i'm not sure how long it's been like that, but i've just let it be. is this something we should fix?
  3. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    If it were me I'd make some drop brackets off the frame where the /forums/images/icons/wink.gif old ones hook it to the frame just make longer hooks that bend down...
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Run the cable through a piece of rubber hose si it moves around inside that instead of rubbign the case.
  5. 76_Cheyenne
    Jan 23, 2002
    285
    Missoula, Montana
    I have a feeling that if it can rub through the metal it would cut through the rubber tubes. I think maybe ill just rig it so the brake only holds the drivers side wheel. I'd rather have one parking brake then, not using it at all.
  6. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    I just did away with the parking brake completely /forums/images/icons/smile.gif after the disc brakes were installed, i didnt have much choice.
    i think the rubber hose thing is a good idea. grease the inside and I bet it will last quite a while.
    mike
  7. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Not required for me. So I cut them off. I am going to go to a tcase mounted p-brake when the new tcase is in.
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Run the cable through a piece of brake or fuel hard line, put that inside a rubber hose with grease. Rubber hose should be shorter than hard line and placed against the case. It will take a long time for the cable to eat through the fuel line. When it starts biting into the tube, the grease on between the rubber and tube might allow the tube to slide in the hose which would last a very long time. Hmm, maybe a simple ferrule (swag) on each side of the tube to make sure the tube is moving with the cable? Just a thought...
