What have you busted in your D44/10 bolt FRONT axle?
Discussion in 'The Garage' started by heavy4x4, Mar 20, 2004.
  1. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Just looking for a general idea of what breaks the most. What I'd like is for you to list your tire size, 10 bolt or D44, what you've broken, and how many times.
    Made-up example:
    35" tires
    D44
    Locking hub (1)
    RH outer axleshaft (1)
    Axleshaft U-joint (2)
    etc.
    Thanks!
  2. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    10 bolt
    35" tires
    rf axles inner and outer-3
    warn premiums-2
    Inner seals-3
  3. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    D44 w/ 40" TSLs
    2 longside shaft inners.
    1 set of spiders from the ring gear bolts that decided to back out.
  4. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    D44/ Detroit
    36's
    1 u-joint/stub yokes/long shaft yokes all at once
    went to D60 3 weeks later /forums/images/graemlins/whistling.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  5. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    Warn Premium hubs
    Spicer U-Joint
    Ring gear teeth
    33s, Open
  6. bugspray
    bugspray 1/2 ton status
    Jan 13, 2004
    110
    Phx, Az
    D44
    37 12.5 15 Super Swampers TSL's
    3:73's Lock rite's
    MM hubs
    I've had it 4 years. I had 35's most of the time, and just broke the short side inner axle shaft (at the part that taper's). Both the seals needed replaced too, they were shot. I went ahead and replaced the ujoints too.
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    10 bolt
    35" tires & lock right
    Nothing yet. It will happen though. I carry wheel bearings, spindle, axleshafts, ujoints, locking hub, and yoke for it. I also have 4 sets of axleshaft for it just because I will probably need them someday.
    I have seen D44's break
    Longside & ujoint (1)
    shortside & ujoint (1)
  8. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Dana 44 with Detroit Trutrac
    4:56s with 35s
    and now 4:10s with 38s
    passenger side both ends after the u-joint broke.
    I have seen lots of 10 bolts, D44s and other front diffs (AMC20s etc) break stuff, and 9 times out of 10, its the u-joint that lets go, then takes out the axle ears with it. If you are planning to upgrade, you have to do both axles and u-joints. In my opinion, Id leave the hubs so at least you have a relatively cheap easy replacement instead of gears or locker.
    But thats just my thoughts.
    Oh ya, and before anyone asks: I know I went the wrong way 4:56s with 35s to 4:10s with 38s. Reasoning was simple. I couldnt afford the 4:56s for the 14FF, so I swapped the front D44 to match the rear end until I could afford the gears... now I kinda really like the 4:10s, so the plan is to stick with them, and double the t-case or tranny. you know... before anyone asks... hehe.
    /forums/images/graemlins/dunno.gif
    Mike
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    31" tires
    10B
    drivers stub(1)
    pass stub(1)
    both joints(1)
    3.08 gears
    breakin s hit with a stock setup sucks the fat one...
  10. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    8 lug D44,4.10,35s
    3 axle u-joints, carrier(pretty sure it was the spider gears)
    Haven't broken anything yet with the 38s /forums/images/graemlins/dunno.gif
  11. DERBINATOR
    DERBINATOR 1/2 ton status
    Jan 26, 2001
    196
    YANKTON,SD
    D44 8lug
    38" tsl
    many axle joints, both sides, usually ending in axle yokes being broke
    spider and ring gears (1)
    added lock right and wheeled once since and broke 1 axle joint
  12. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Used to run a D44...
    3.73 open
    33" AT's
    Big block /forums/images/graemlins/laugh.gif
    Superwinch hubs- 2
    Spider/side gears- 2 sets
    Kinda wierd that the spider and side gers blew apart before the stub's or hubs at the time. Steering was at full lock to the left trying to climb a muddy hill with roots. Pretty decent amount of throttle. One little hop/bounce on the roots and they popped. Interesting noise too..BANG! popopopopopopopopop....lol, like a little machinegun. /forums/images/graemlins/histerical.gif
  13. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    10b
    33' tires
    4.56 and ARB
    not a damn thing!....yet
  14. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    1978 K20 Bobbed Flatbed
    D44
    38x13x16 TSL Bias (measure 36")
    Passenger side stock stub at splines
    Passenger side Milemarker hub
    Rear axle hung on rock, open 14BFF, one tire in the air so no traction, both front tires on soft dirt, hald throttle turning the wheels back and forth for traction and kablammo
  15. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    73 blazer
    8-lug44 with a trac-loc
    36 SXs
    ran this combo for 7 years....lost track of broken u-joints,stubs and shafts......5 ring gear bolts came out,5 sheared off and took the ring and pinion with..in january....now have a 60
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    38.5x16x15 tires
    4.10s open
    10 bolt front
    350
    U joints (2)
    Inner shafts (both sides one each)
    Outer shafts (same)
    Haven't had any issues with the '60. /forums/images/graemlins/thumb.gif
  17. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    my knuckle, removing it to install D60....
    Grant /forums/images/graemlins/waytogo.gif
  18. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,008
    197
    Santa Maria, CA
    My 73 with 33 tires 10 years ago.
    2 4:11 gear sets
    2 4:56 gear sets
    2 sets of spider gears
    3 u-joints along with short side axle shafts.
    I've yet to break anything on my 74 with 3:08 gears on 31 tires.
