What have you done to level your rear
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by eastk5, Apr 9, 2002.
  1. eastk5
    eastk5 Registered Member
    Jul 24, 2001
    50
    Norfolk Virginia
    I have an 84 k5 with rancho 2.5 springs at all corners. the front has the addition of ORD shackles. when measured on from the ground to the body line(not the wheel well lip) there's about a 13/8" difference. I was going to get the ORD zreo rate but i would still be short. BTW this is measured with the hard top on and a full tank of gas 31gal.
    Any ideas appreciated, sorry this is so long!
    Joel
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Add-a-leaf's although they stiffen the ride,and sag a bit in the long run. I've had mine for about 2 years now. Haven't noticed any sag.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have 2.5 inch front springs w/ORD shackle. I had 2.5" add a leaves installed for rear lift, but they sagged. So I installed the 1" zero rate addaleaf from ORD and that took care of my problem.Your truck will have alot less sag with the 1" zero rate in there and therefore look better. Beyond that I really can't help you much. Maybe another 1" addaleaf in the spring pack. Or see if Stephen would make a 1 1/2" zero rate. Never know.
  4. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Mine was the same way, I finally ended up making a set of shackle flip brakets which had about 1 1/2" more lift and now it sits level... although roof off and an empty tank I think it is about 1/2" higher..
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I fine tuned the height AND corrected my pinion angle with a 3/8" 5 degree shim that I welded to zero rates.
  6. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    i cut off the spring perches on the axle, and custom made my own that were about 5/8" taller then te stock perches..
  7. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    I cut 13" off the back of the truck, lost the tailgate, lost the stock gas tank, added a 20 gal alum fuel cell, and chunked the hard top. My truck sits level with a 4" TC EZ ride front and shackle flip rear.
    /forums/images/icons/tongue.gif
  8. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Where are you guys getting your shims?
  9. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    local race shop I bought my 4* shims for $20
