What HD fan clutch to buy?
Discussion in 'The Garage' started by chev4life, Apr 20, 2006.
  1. chev4life
    chev4life 1/2 ton status
    Jun 21, 2001
    416
    San Jose, CA
    Need to replace the fan clutch and maybe fan in my 87 k5, anyone have the part numbers/place to get an hd fan clutch and should I upgrade to an hd fan blade or are they the same thing. Thanks.
  2. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
    IMHO, there is no reason not to upgrade to the biggest fan & clutch available on a trail truck.
    Use a 7 blade fan and a fan clutch from a 83 K30 dually w/ 4.56's - the gear ratio makes a difference. :thumb:
  3. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    Will that bolt right up to my pully and fit the stock fan shroud? I have yet to have probs on the trial...my main probs are towing my boat up hills at 10-15mph in 100deg weather. Gonna put a fan on my tranny cooler to hopefully fix that part of the prob...but I dont get enough air through the raditor at low speeds with the stock w/shot clutch.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I picked the heaviest duty one that I could find in the catalog, along with the 4.56 gear ratio option. Autozone part number 922784. It seems to always engage at idle, regardless of temp. Should be awesome on the trail!
    BTW, that part number is for a REVERSE clutch, used with the full serpentine belt. It won't work correctly if your water pump turns the standard direction. They're direction specific.
  5. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    So I need to ask for a 4.56 gear hd none serp clutch similar to the 922784? What about the blades? Can I bolt my 5 blade up or should I just get a 7 blade?
  6. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
    The 5 blade fan will work if that's what you've got but the 7 blade is better.
    Ask for a fan clutch for this application -
    Any variation from that exact application will not be "the ultimate".
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Unless your rig requires a reverse rotation clutch. :rolleyes:
  8. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
    This question was specific to an 87 K5 which I do not believe would be a reverse set up.
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    87 was a combo year. Part serpentine and part V-belt, but I can't remember which way the water pump rotates. Sold my '87 a long time ago...
  10. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    To the best of my knowledge 1987 had a multi-groove belt along with regular V-belts not a serpentine belt set up . Full serp. belt system did not appear until a year or two later on the solid axle trucks.
    Tom
  11. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    Yup, mine is standard rotation v-belt setup. Can I get a 7 blade fan at autozone or do I need to grab one from the dealer?
  12. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    The last time I tried to get a seven blade fan from GM it was supersceeded(sp) with a heavier pitched five blade fan. I just get good used seven blades from the bone yards when I find them.
    Just look at the pitch of the blades on the five or seven blade fans and get the one with the most pitch. The fan clutch we are talking about will pull masive air with either fan.
    Tom
  13. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    I just checked out autozone and they have 2 part numbers one for a heavy duty (same pn for my 87 as the 1 ton 83) and one for a premium heavy duty..whats the difference if any?...other than price
  14. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    Just got a Haden severe duty fan clutch from my buddy at the chevy dealer...sweet...installing this afternoon. Thanks for the help guys.
  15. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    if you do a lot of deep water crossing dump the clutch fanand get a electric.i killed 3 fan clutches last summer due to water crossings.i regularly cross 3-5' deep water.
