What heads would you go with
Discussion in 'The Garage' started by Z3PR, Mar 16, 2003.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
  2. jtpepper
    jtpepper Registered Member
    Jun 4, 2002
    43
    LOCKHART,TEXAS
    Definently the torquers.Much better head.My friend has a set on his chevelle and he's turning 11 second passes.GOD Bless,jtpepper
  3. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    can you drill the vortec heads for steam holes? also wouldn't you need to ease the edged of the combustion chambers to avoid detonation do to the larger bore size of the 400?
  4. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    If you already have an intake manifold use the S/R. The Vortec take a special intake and that will set you back about $170. You also cant run over about a .480" lift with stock vortec springs. Also require self aligning rockers. If you dont have these parts, things can add up fast. /forums/images/graemlins/eek.gif
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Get the S/R Torquers. I have the 67cc versions on 388. Great heads!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif
  6. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    If you can swing the extra $$$$ get some AFR's and call it a day.
  7. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    I second the AFR's. Do yourself a favor and check out Pro-Topline. They offer "stock replacement" heads in iron with improved vortec-style chambers, and their prices are very reasonable. They also offer Iron Lightning heads with 180 CC runners which should work well with your 400. Their flow numbers are MUCH better than the torquers, and better even than the vortecs, and they are available in pre-86 and 87-up intake patterns.
  8. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    ya and midwest motorsports has great prices on them.....the pro toplines...
