what/how is synthetic oil made?
Discussion in 'The Garage' started by big_truxx, Aug 28, 2005.
  1. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    what is synthetic oil made of? it's not petroleum based correct?
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Synthetic I think is a chemical reaction of some stuff. To my knowledge in a full synthetic there are no dinosaurs.
    If I am wrong someone will correct me.
    Ira
  3. roadhawg
    roadhawg 1/2 ton status
    Aug 15, 2003
    495
    Oregon
    Synthetic oil is made of plastic polymers
  4. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    :saweet: thanks
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Isn't plastic a petroleoum product. Looks like they take oil and make oil?
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    And plastics are made from a petroluem base. :doah:
  7. sandawgk5
    Oct 28, 2003
    6,881
    I am pretty sure that some of the new plastics do not require petroleum. They may use oils to make them just not petroleum based oils. I dunno intersting discussions to follow I am sure.
    Ira
  8. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    :doah: so when the oil runs out so does plastic
  9. roadhawg
    Aug 15, 2003
    495
    Oregon
    well maybe i am incorrect i would not think they would take oil to make synthetic oil? May someone can elaborate further.
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Found this: "Crude oil is the most common raw material for plastic monomers, Rubner says, because ``it's the most abundant, cheapest, easiest-to-use supply of the organic chemicals you need to make monomers.'' About 4 percent of crude oil turns into plastics." Here: How is plastic made?
    A somewhat more technical discussion can be found at:
    http://www.plasticsresource.com/s_plasticsresource/sec.asp?TRACKID=&CID=126&DID=228
  11. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    its butter--no,its chiffon!
    I read somewhere margarine is only 1 molecule away from being plastic!--it was discovered by accident during WW2 when they were looking for a way to make plastic without oil,or something like that..I thought that was weird! :screwy: ...is it Chiffon??--no,its "roatella".. :doah: :eek1: :haha:
  12. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    PAO ( poly apha olefin ) synthetic oils such as mobil one / royal purple are made from compressing natural gas molecules into droplets of uniform size. different hydrocarbon chain, but still a hydrocarbon.
    Tom
  13. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    I was told that it is regular oil only they do something to it that makes all the molicules the same sizer or something.
    And alot of plastics are made from soybean oil.
  14. 4by4bygod
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    There is something called a group II oil, which is a mineral oil that's been refined and hydrotreated many times over, making the molecules pretty similar. That's how castrol is made, and they won a court fight, being able to call their oil synthetic too, just like the PAO's.
    You also have ester based oils, which are good at absorbing heat, but will also swell your seals. everyone went to PAO because it's cheaper than ester, and of course the group II's are cheaper still. redline is an ester base, and amsoil used to be.
    pretty much any PAO , ester , or mineral basestock blended with solvents and detergents can be called a synthetic nowadays, thanks to the castrol court case. The trick is to study the different types of basestocks, and how they react under combustion temps.
    Tom
  15. Mudgod
    Mudgod Registered Member
    Dec 19, 2004
    92
    Gilmer, TX
    Tom your right on the money here.
