What HP would you need to smoke the tires off the line.
Discussion in 'The Garage' started by FWP, Feb 5, 2007.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Just for fun. 6000 lb Blazer, 3.73 gears, TH350, 33" tires. :D :D
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    I have 5500lb truck, 5.13's, th400, and 37 inch tires. I can turn them off the line pretty easily, not smoke, but chirp for a few rotations. Check out the videos here to see the burnouts, and watch the race video for great audio of them spinning off the line from a punch with no brake stand.
    Video's Here
  3. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Torque is what you're really going to want, but I'd say 300HP/ 350TQ would get 'em spinning, and anything more than that would only make it easier. If I were building a engine from the ground up, I'd shoot for at least 350HP/ 400TQ, which is easily attainable from a 350 or 383 with Vortec heads. With good heads and a roller cam, 400/500 isn't too hard to do, especially if you start with a 400 or BBC. For a BBC, I'd want 500+ TQ.
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Got Dyno #'s?
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I'm gonna build an SBC. :)
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Nates new Blazer will do that with a healthy 350 ( no Nate I don't believe its a 305 :deal: ) 4.10's , and a th350 with a 2000 rpm stall converter . Its more of a weight issue in a truck .
  7. NateInChandler
    NateInChandler 1/2 ton status
    Apr 23, 2006
    418
    Chandler, AZ
    fred, my yellow truck comes damn close to smoken em off the line.. dont know what it is about it, but i can get a few chirps out.. 33's 4.10's and a 700r4 with a mild 350 tbi motor.... Heres some specs that could get you some smoken power from a dead stop.. ive had this combo in two trucks in the past
    start with a fresh or low miles 350, add vortec heads (or the good 305HO heads)with a comp XE 262 cam, about 9.8:1 compression (runs FINE on pump gas with the vortec heads), a edelbrock performer rpm intake and a good tuned edelbrock or a holley, i had 4.11's with 35's and a Th350 203 combo.. used to blow the tires off when leaving school in the afternoons with no power brakes or anything, had raw torque... the 305 heads i had on it didnt really make that much top end power, but BOY O BOY was it peppy around town... i think i even have a picture of me smoken em from roll with some cheap 31's, but this was all on a truck, much less weight in the rear than a blazer.. so it may take more with a blazer... Nate
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I wouldn;t run 305 heads when new vortecs are cheaper than a remanned set of stockers at Sumitt or Jegs .
  9. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    about 350hp and 500tq or so
  10. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Why Vortec heads? Why not Aluminum aftermarket?
  11. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    :bow: :bow: cool.
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If you want to spend that much , go for it :waytogo:
    AFR , World Products , take your pic :D
  13. bowtiepower00
    May 11, 2000
    924
    AZ
    Vortec's are the best heads for the price. Many of the aluminum heads flow better, but they cost several hundred dollars more. If you can afford aluminum, look at Brodix's IK180's (about a grand), or if you have a bit more to spend, AFR's 180's.
  14. NateInChandler
    Apr 23, 2006
    418
    Chandler, AZ
    Fred, you can get whatever you please, but make sure it has a low cc intake port, anything bigger than 175 is gonna kill your bottom end torque, the vortecs have a fast burn swirl type chamber and it is AWESOME for making some killer power... Nate
  15. NateInChandler
    Apr 23, 2006
    418
    Chandler, AZ
    btw, paul is wrong here, i ran the numbers on the block and both heads, they all match to a early 80s smogger 305... but as everyone knows i do have some goodies on and in it... HAHA>> NATE
  16. bowtiepower00
    May 11, 2000
    924
    AZ
    You are going to have trouble finding a set of aluminum heads with Intake runners smaller than 180CC. The only ones that come to mind are the L98 vette heads, and they don't flow until you really work them. Vortecs are around 170CC, I've read they actually measure closer to 165CC.
  17. NateInChandler
    Apr 23, 2006
    418
    Chandler, AZ
    coulda swore the gm casting fast burns were 170 cc's when all said and done... ill hafta double check.. either way, 180 is kewl, wouldnt go more than that though.. i had 210's on my STRICKLY race truck and it killed the bottom end power but i gained it back in the 2nd part of the 1/4 mile
  18. bowtiepower00
    May 11, 2000
    924
    AZ
    The Fastburn is 210cc. To see the difference between heads on a 350 (in this case, crate engines from GMPP), the ZZ4 and Fastburn 385 are the same shortblock (and cam) with different heads. The ZZ4 (with L98 Corvette TPI heads) is around 355HP and 410TQ, and the Fastburn is around 385/385. The aftermarket aluminum head's better flow usually makes up for the larger runner- if the head flows well. In this case the FB's runner is just too large. That being said, if you're looking at aluminum, you can do much better than either set. The Vortec heads will make just as much power as either one- more in most cases.
  19. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Sheesh:confused: What a discussion:rolleyes: Informative though:D
    Just go out and buy some bias ply truck highway tires. About 6.75" width. Brake Stand and smoke the poo-poo out of them!:haha::haha::haha:
    Edit to Add:
    A cup of bleach over both rear tires to be sure:crazy::haha::pimp::pimp1::thumb::saweet::screwy::woot::yikes::k5:
  20. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    Yah...we know about smokin' tires, eh?
    I can't get this black stuff off my arms...:eek1: :haha:
