What I work on
Discussion in 'Center Of Gravity' started by ntsqd, Jul 28, 2004.
  1. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    This might not be the correct place for this post (I've no issuues with it being moved), but given the nature of my work it seemed like the best place. I'm having so much fun working on this project that I thot I'd share. I get paid an Engineer's salary to play with engines, how cool is that?
    APT
    The OPOC engine design is scaleable. Not sure how much I can say beyond what the page has on it so ask Q's if you've got some and I'll answer what I can.
    How about some sort of buggy powered by a bigger version of this?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    is it just a boxer style engine like Subarus? I don't see anything other than outside shots of it. I've seen comp buggy's powered by Subaru motors. If you could get your hands on a WRX motor or STi motor that owuld be a sweet powerplant for a buggy.
  3. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Could you explain the 2 pistons per cylinder /forums/images/graemlins/confused.gif
    It doesn't sound like it means two cylinders per side, so I'm a tad confused.
    And what is so revolutionary about the engine, rotary aircraft engines work on the same principle as do Ferrari flats, Porsche powerplants. . . I'm just curious what makes this one so different?
    It looks like the engine a buddy of mine has in his R/C Sandpiper though, cool engine.
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Thats what I'm looking for, it seems to be the same setup as has been around for a long time.
  5. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Looks like a smaller version of a Lycoming or Continental aircraft engine. Major difference is that yours is a 2-stroke and the Lyco and Conti are 4-stroke.
    Still interesting though.
  6. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Not for nuthin and call me an ass if it is applicable but, this looks kinda like a really big complicated model toy gas engine all opposed n stuff. Don't get me wrong I think it's a really cool idea /forums/images/graemlins/thumb.gif but ain't it pretty much the same concept?
  7. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    Cool! So if I am following this correctly the scale version pictured is a four piston two cylinder 2-Stroke. How are the two pistons in a single cylinder connected and how is that reciprocating assembly connected to the crank? Where are the two combustion chambers located?
  8. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    OPOC stand for "Opposed Piston, Opposed Cylinder" meaning each of the two cylinders has two pistons in it, one at each end of the cylinder. I.E. there is NO cylinder head. Combustion takes place btwn the pistons. Connecting rods connect each piston to the single crankshaft.
    I've had several friends offer to test it for us. From small motorcycles to racing Barstools. MISF hasn't shown much interest in it yet, but when he does we'll have Product Durability Testing in the bag. If he can't break it, it can't be broken.
    This one should make 10-15 HP. There are much, much higher output versions being designed now.
  9. jarheadk5
    Mar 6, 2000
    4,389
    PA
    OK, so there are TWO cylinders, and FOUR pistons. And all four pistons have con rods? How the hell is that done?!
    I guess that's probably one of the things you can't tell us, so I guess that question will be rhetorical...
  10. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Outer pistons have a pair of con rods each.
  11. jarheadk5
    Mar 6, 2000
    4,389
    PA
    OK, I can visualize that... Interesting. Much more so now that I understand it better.
  12. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Fairbanks Morse has done this for a LONG time as far as I know.
    Edit:
    It looks like its actually completely different than an old Fairbanks Morse diesel.
  13. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    The only Opposed Piston engine I could turn up searching b4 I accepted the position was a Teens or '20s era F-M with two cranks that were geared together.
    'Ours' has only one crank.
