What If
Discussion in 'The Garage' started by 1986chevy_rider, Nov 28, 2005.
  1. 1986chevy_rider
    1986chevy_rider Registered Member
    Nov 8, 2005
    97
    fallon nv
    What if I could come up with a turbo 400 with a np 205 x-case is that a good set up what kind of work would that require to put into a manual trany now with a 208??
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    flexplate, new or modified crossmember, and driveshaft work should be about it. possibly a different speedo set up
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    yes its a good setup... your gonna feel less power with the th400,, if i remember some estimated about 10-15 horses less.
    but if you keep fluid in the tranny, and keep it cool.. it is the one to have if your gonna run an auto.... Furthermore, when you go to a doubler, you already have the right spline count on the input shaft.
    obviously your also gonna need a way to shift it... id go out and get you the B&M light truck ratchet shifter
