WHAT IN THE WORLD IS THIS????
Discussion in '1982-Present GM Diesel' started by AzzKicker, Aug 29, 2002.
  1. AzzKicker
    AzzKicker 1/2 ton status
    Jul 28, 2002
    265
    Edinburg, Tx
    I dont think this is Factory installed. I can tell by the brackets. I know its a Fuel filter, but is it needed. Should I remove it. Whats the deal on this.
    By the way i just got this truck and its my first diesel. So i'm new at this.
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    SOME DAMN CLEAN FUEL, THAT'S WHAT IT IS. Seriously, it's just a little over the top. The factory (box style) filters weren't bad. The did have a heater, water sensor, and some(all?) a restriction sensor. They were prone to air leaks (the mount itself).
    On you dual filter mount the primary was used as a fuel/water seperator (usually), the secondary as the filter. You could keep it or ditch it (keep just the factory), or if you're like me ditch the factory filter and run the aftermarket unit. But don't ask me I run (just) a Racor filter.
    /forums/images/icons/wink.gif
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    What you've got there is an aftermarket or hobby-jobby fuel filter relocation setup. The original fuel filters are located in tough to reach spots, so a lot of people use relocation kits to make the job of swapping filters out a lot easier. You should be happy that the PO went to the trouble of installing them!!! /forums/images/icons/smile.gif
    Since we're on the topic, one of the first things you should do is change those suckers out. As a rule of thumb, fuel filters should be changed yearly.
  4. Can Can
    15,552
    136
    Damn, Dan, you beat me to it!!!! /forums/images/icons/smile.gif /forums/images/icons/wink.gif
  5. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Perhaps the PO worked at a truck shop and got his fiters at a discount.
  6. Txstruck
    Txstruck Registered Member
    May 25, 2002
    87
    Seagoville, Texas
    Dan, mine has the square filter and it sucks air. How can I fix it? Just replace it? /forums/images/icons/confused.gif
  7. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    Supposedly the factory fix is to remove the sensor (not sure which) tap the hole and install a plug. 'Never done it, I've always replaced the mount.
  8. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    Tke a look into the trunk, perhaps there are also a few filter?!
  9. AzzKicker
    Jul 28, 2002
    265
    Edinburg, Tx
    Only problem I seem to notice now is I cant find these Fuel Filters. The local parts stores dont cary Fuel Filters in that form.
    Would I have to go to a 18 Wheeler place or what?
  10. Can Can
    15,552
    136
    Huh? What's that supposed to mean? Are you inferring that the cost of a couple of filters a year isn't money well spent? /forums/images/icons/tongue.gif
  11. Can Can
    15,552
    136
    You're kidding!!! /forums/images/icons/shocked.gif
    You might want to try your local farm equipment or heavy equipment dealer/ service center. Right now one of my spin-ons just happens to be for a Case backhoe, but it fits perfectly on my setup.
