What is a GOV LOCK?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mr7dblzero, Aug 27, 2002.
  1. Mr7dblzero
    Mr7dblzero Registered Member
    Apr 11, 2002
    16
    I have a 14 Bolt rearend on my 1985 Suburban and I wanted to know what is a GOV LOCK and how could i tell if I have one? /forums/images/icons/confused.gif /forums/images/icons/confused.gif
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    A Gov-Lock is a POS. /forums/images/icons/tongue.gif
  3. Mr7dblzero
    Apr 11, 2002
    16
    So is it like a Locker or something?
  4. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    What Westy is telling to tell you is that it(gov-lock) is in retail words a POS(Point Of Sale)......Uhh No that's not it.It's A Piece Of Sh*T!GM's version of a locker...Look out there she blows!!!LOL /forums/images/icons/blush.gif /forums/images/icons/shocked.gif Mike
  5. Mr7dblzero
    Apr 11, 2002
    16
    Thanks guys for the info I guess I gotta get a locker or something then. Mahalo (Thank You)
  6. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    yeah it's kind of a limited slip, they're not that great mine's starting to suck now. sometimes it won't lock some times it won't un lock.
  7. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    What the others may have failed to say is that it is a limited slip unit built by Eaton.....a VERY loose limited slip unit..... let me rephrase that.....apiece3 of SH*T, not fit to be a boat anchor.
    Hope that helps /forums/images/icons/grin.gif
  8. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    If its in a 1985 Sub its probably a 14 bolt semi-floater (9.5 ring gear). I have been running a GOV-LOK in two different trucks in a 14 Full-floater (10.5 ring gear)and they both work great in rocks, mud and snow. They have not been babied.
  9. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    um yeah I have given my gov-lock (14FF) some abuse and its held up. It does a pretty good job of locking, and no its not limited slip, that is misleading. its a locker but it takes some real wheelspin for it to lock. its much different than a detroit. Not nearly as strong, but it works. Could break tomorrow, could last another 25 years
    mike
  10. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Mine works pretty good--AS LONG AS YOU HAVE 14 oz's OF POSI LUBE AND NOT 7!!! then it sucksssss.
    rob
  11. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    Let's clear up the mis-information here:
    Gov-lock is not a LSD. It is a locker, meaning that when it engages, both shafts are locked together with no slip allowed. It does this by centrifugal force. The differential is 100% open until one wheel spins faster than the other by a certain amount. Then it locks the two sides together. It unlocks when you reach a certain speed (by overall speed of the carrier) or after you have removed all of the load from it.
    They have a general reputation for being junk, based mostly on blown-up 1/2-ton units. Generally they hold up a lot better in the 3/4-ton and 1-ton versions (i.e. 14B S/F and 14B F/F). You have to consider that open 10-bolts blow up fairly regularly too, so chances are that the gov-lock doesn't deserve all of the blame that it's given. Plus, there are millions more miles on these than people have on their aftermarket differentials, so overall age and wear is against them.
    Advantages: 100% transparent on the street, better than a LS or locker. Unlocks at higher speeds, making cornering safer than with a locker. Gives full locking, which is better than a LS. Available in most junkyards. No gear setup required if you just swap the axle.
    Disadvantages: Weaker than some other options (especially in the 10-bolt), You have to spin a wheel to get it to engage. This can be difficult on the rocks and get let you dig a hole under a tire that a locker/spool would not. You may not be able to stay locked at higher speeds. This is great on the road, but could be a problem in mud holes or sand, depending on how much you're spinning. The carriers are usually different than the open diff units, so you probably won't be able to pop in a lock-rite or Detroit (14BFF).
  12. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Nice post Blue. When I opened this, I was wondering why it would take 10 replies to answer that simple question.
    Oh, and on the '85 Burb, look in the glove box for the RPO code G80. That indicates that you have a Gov-lock.
  13. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I was wondering if anybody had a picture of a 14bFF gov loc installed in the axel, I haven't had my truck offroad yet so I don't know if I have one. Oh, Blue, what part of Michigan do you live in?
  14. jstevenj
    jstevenj Registered Member
    Aug 28, 2002
    94
    north Miss.
    You can probably jack one back wheel off the ground and see if the truck will pull itself off the jack. At least the on I used to have in a 10 bolt would.
  15. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    It's a goofy locker.
    Do a search and there will be directions to tell if you've got a Gov-Loc. The easiest way to tell is to pull those 14 bolts and have a look-see. It's also an incentive to put a few quarts of fresh oil in.
    A Gov-Loc pretty much works on centrifugal force to engage it. In theory it should only take a couple mph to get it to engage but in reality a sloppy one or one with springs that are too tight won't engage until a tire is going ~10mph. They disengage at about 35mph with 235x75R15 tires and 3.42 gears on a 10 bolt and 245x75r16 and 3.73 gears on a 14FF. A blip of the throttle will usually encourage them to engage and if you get up to ~30mph you can get it to disengage by unloading the drivetrain (let off the stupid pedal).
    The pieces in them are really small. On a ten bolt they're even smaller. They just itch to grenade, hence the "grenade-loc" name they've earned, when people abuse them. When I mean abuse, I mean abuse. A Torsen differential will go AWOL just as easily as a Gov-Loc.
    A 14FF with a Gov-Loc in it will handle 33" tires without a problem. It'll even handle the classic spin-one-tire-like-mad-on-gravel-and-then-hit-dry-asphalt move. This is what usually kills the Gov-Loc. It's also the #1 killer of 10 bolts (including open differentials). "eh mon, ain't these spider gears on my ten bolt supposed to have teeth?" "nah d00d, that's just unnecessary unsprung weight and it ain't nothin' a Lincoln can't fix!" "eh mon, my ring gear is missing teeth too!" "that ain't matter none, it just adds this cool clicking sound that makes people think you've got a real detroit!"
    I've lived in northern Michigan too long. "you know you're a yooper when the only way left to balance your tires is to cut off lugs".
    I forgot to mention, I have pictures somewhere of a 14FF with a Gov-Loc and 40" TSLs on the ends of it. It became a Grenade-Loc and the cover had some mean looking outward dents. A local guy told me he's seen a cracked case from a Gov-Loc going AWOL. I'd think the pinion gear would bust off before this happens on a 14FF though so I don't know if I'd believe him.
  16. dyeager535
    26,982
    191
  17. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    [​IMG] [​IMG]
    These are the same Gov lock, different angles!
    Here, the best way to tell is by counting the dents/holes in teh side of the ring gear. These are the pivot points(mounting shafts) for the spiders or locker plates inside.. A gov-lock has 3 holes, an open carrier or Detriot has 4!!! /forums/images/icons/cool.gif
  18. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    I was told this is a GOV LOC.It's in my 71's 12 bolt.
  19. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    I tell ya, heres what I hate- on the trails, it will lock up fine and both rear tires will be digging, then you stop to change lines and it wont lock back up unless you have ALOT of wheel spin. Gets pretty old.
    rob
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have one in my 14 SF and if I keep the axle I'm gonna weld it cause I'm sick of it acting up.
    Mine likes to do all kinds of funny locking-unlocking maneuvers when I'm spinning my tires hard in the mud.
    I'd bet if it was a 10 bolt one, it would have came apart by now.
