What is a lunch box locker?
Discussion in 'The Garage' started by fireplug, Dec 15, 2005.
  1. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    Among the spare parts that came with my new truck was a 12b with a lunchbox locker. What is this?
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    A "locker" that installs in an open carrier replacing the spider gears. Does not require the gear removal(in most cases). i.e. done in about 1 hour.
  3. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    So what brand would this be? What are the characteristics of this locker?
  4. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    Aussie locker, PowerTrax, etc.
    It's basically two big pieces with interlocking teeth that replace the side gears. Keeps the shafts locked together. If load gets too much the teeth will slip and you'll hear a ratcheting sound. Installs in about an hour or so, typically without removal of the carrier.
  5. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    lockright, aussie, detroit ez locker
    they are fairly cheap ie 350 max but decent for a front i would rec for rear Lincoln Locker or Detroit
  6. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    So I have no use for this as I have two 14bff/Detroit. What would a 12b with the lunchbox locker be worth? Are they half decent?
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    They are fine units if made by Powertrax/Richmond . And I would gladly buy it if I did not already have one for each 12 bolt I own . I'd say it worth half what they sell for new if you post it up , because its used , and realistically wouldn't want to buy a used one for more than a bill without knowing the history .
