What is a normal amount of body flex?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76_Cheyenne, Apr 17, 2002.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    I have a 1976 K10 1/2ton and I am experiencing an unusual amount of body flex. This week I was wheeling in the Moses Lake Sand Dunes and got stuck fully articulated with one rear tire off the ground and the truck body and bed flexed around 6-9 inches, somewhere around there. For some reason this doens't sound right. The bed made large scratches on the body for rubbing it while articulated. Also the steering coulum was all messed up and I could't get the tranny in the gears i wanted because the coulum was so twisted. I know my steering box area isn't broken and I got a brace there. It all lines back up almost straight, the way it has alway been, and drives fine once it was level again. Could this be do to bad body mounts? Any other ideas? Im afraid im going to twist the frame. any ideas would help a lot, thanks.
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    If you still have the rubber mounts, that is certainly part of your problem! Also, you might want to look for body mount holes that might have pulled thru... mine started flexing like that after I pulled thru two mount holes on opposite corners. I'd swap the mounts with a new poly set, and see what that does for you... /forums/images/icons/smile.gif
    Just my .02
    -Dan
  3. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Pickups will have more frame flex than Blazers. And I've noticed that stepside beds will allow for more frame flex than fleetsides. And it makes it even worse if your suspension is kinda stiff - cuz the frame flexes instead of the suspension when you get in a twisty spot.
    The best way to solve it is to add a full rollcage that ties down to the frame somehow. Softer springs will also help some. Left alone, the frame will flex enough to allow the bed to hit the body again. I don't think you can hurt the frame by flexing, just gonna dimple the body where the bed hits.
    Marv
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    My old stepside bed mauled the back of my cab with a three inch body lift. The only way I could see to fix it would be to strengthen the frame somehow. I ended up selling it and buying a K5 but not only for that reason......
  5. BARRAZA
    BARRAZA 1/2 ton status
    Oct 17, 2001
    259
    USA
  6. 76_Cheyenne
    Jan 23, 2002
    285
    Missoula, Montana
    Thats almost how much flex was on my truck, maybe just a tad less.
  7. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Well, I was going to come in here and moan cause mine flexed enough today to prevent me from opening the drivers door due to the front fender binding with it... but after that Skyjacker link... I've got it good. What I hate the most is when you get crossed up and hear the roof sheet metal pop as it distorts. I decided the cage was a necessity today when I exited through the passenger door.
  8. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Well...I flexed my blazer so much this past Saturday that I trashed my top. My old 77 short wide used to flex like a futher mucker too, but it would straighted right up as soon as it was level. There isn't too much you can besides what Marv said. Other than that, you live with it and don't do stuff where you'll flex that much, or you live with the body/bed contact.
  9. 1bad82k5
    1bad82k5 1/2 ton status
    May 8, 2001
    185
    MT
    I flexed mine up enough to crack the fiberglass top. Also, when i pulled my headliner i found two cracks. They are in the roof right behind the wing window. There is one on each side of the cab, and they are about 6 to 8 inches long, and steadily progressing.
    eric
  10. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    That's a good reason why I'm NOT a fan of frame flex. Although an UNpopular opinion /forums/images/icons/blush.gif (or so it seems); I think that flexing should be left to the suspension which is made of spring steel; not the body & frame! My new frame is 2x5 3/16" steel tube which will also have an 8-pt cage further stiffening it from the engine bay all the way to the tailgate.
    This has come up many times in the past & I'll still weigh my vote in on the side of a stiff frame & flexy suspension! /forums/images/icons/smile.gif
    I'd say box it or mount a cage or do something to stiffen it up!
  11. Blue Meanie
    Blue Meanie Registered Member
    Apr 12, 2002
    61
    southern New Jersey
    you can always try to box the frame by welding or bolting metal between the frame in different sections. i too have the frame flex, but don't really care about body damage. i am going to use some 3x3 angle iron to beef up the frame sometime in the future. i'll put up pix
  12. Grim-Reaper
    7,385
    Atlanta
    Damn, was that all it flexed? My buds 78 I have seen the bed mounted roll bar look like it was 45 degrees to the cab. I had a picture...I'll try to find it and post it somewhere /forums/images/icons/smile.gif
    That's normal for a truck. You could do a full tied to the frame gage through the fire wall and the back of the cab to stop it but your going to have to do some major suspension mods to get the wheel flex.
  13. 76_Cheyenne
    Jan 23, 2002
    285
    Missoula, Montana
    So this is normal then. That makes me feel better. So I don't need to worry about anything breaking? well I guess I always have to worry about things breaking when the trucks this old, but as far as broken frames? I dont mind the scratches on the cab.
  14. Grim-Reaper
    7,385
    Atlanta
    Big place to watch out for frame breakage is around the steering box. also need to go over the frame and make sure it isn't blowing out the rivits that are used to hold the cross members to the main rails.
    As for as it cracking....yeah it can happen most of the time it's not the frame in the rear that crackes it the front where the frame starts comming up to go over the front axle. That's where I have seen them cracked. I think it's because the cab limts the frame twisting at that point so it becomes a high stree area.
  15. 76_Cheyenne
    Jan 23, 2002
    285
    Missoula, Montana
    Ok good, Im not really worried about over the steering box because I have a frame brace. But ill check the rivets. I have a picture of the flex so ill try to get that up.
