What is a shackle flip?
Discussion in 'The Garage' started by jeff l, Jun 19, 2006.
  1. jeff l
    jeff l 1/2 ton status
    Jun 13, 2006
    104
    New Orleans
    I am sure this is a stupid question; but this is my 1st truck I am rebuilding, and I am hearing a lot about shackle flips.
    Thanks, Jeff
  2. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,235
    284
    San Jose, California
    Without any pictures, it's more difficult to explain, but if you look at the rear suspension of your truck, the leaf spring is connected to a small hinged bracket near the back of the truck) In a stock truck, the leaf spring holds this bracket under tension. A shackle flip rotates the bracket ~180 degrees around so it's under compression. The reason for doing this is to give you a nice amount of lift (~4") without having to get new springs which would make the ride rougher, or add any blocks. If you look at the truck, it's pretty easy to see what I mean. Also, take a look at the tech articles section on here, it explains the installation.
    I got one from ORD (Off Road Design) and it worked great.
  3. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    As stated above plus on a personal note, I've just done mine and my rear suspension is now much more flexible and reacts faster than before. I have the stock original springs still but you more movement, more easily...if that makes sense?
  5. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Got a picture for ya
    This is when I did mine...
  6. ryanstrucking
    ryanstrucking 1/2 ton status GMOTM Winner
    Feb 2, 2003
    182
    Calgary AB Canada
    heres a pic of mine.
    Cheers
  7. jeff l
    Jun 13, 2006
    104
    New Orleans
    I see thanks a lot for yall's help
    Jeff:D
