what is a...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FatBoyBlazer, May 15, 2001.
  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    what is a spool???????????
  2. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    i answered that in the other place you asked
  3. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    so then why are they bad to run on the pavement
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Because in a turn the outside travels a longer distance than the inside. With a spool the inside tire will scrub (because it has less load on it).
    '71 Blazer CST with alot of rust
  5. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    With that inside tire slipping it could cause you to spin out, especially on wet pavement. You just have to learn to drive with the new characteristics. It's been done before.
