What is AGK used for
Discussion in 'The Garage' started by CK5, Oct 16, 2005.
  1. CK5
    May 19, 1999
    21,624
    702
    CO
    In the wiring of my 90 Blazer I have a modual or something labeled "AGK", anyone know it's purpose?
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    How many wires and where was it located?
  3. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    IIRC, is it white and located under the dash near the steering column? if yes, it is the DRAc, and you need it for your speedo to work
  4. CK5
    May 19, 1999
    21,624
    702
    CO
    yep, that sounds like it, I don't have a speedo anymore but wonder if I need it in the future if I get a aftermarket speedo?
  5. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you might want to keep it if you have kept the fuel injection so the computer knows vhecial speed.
  6. dyeager535
    26,980
    ABS, Cruise and ECM all work off of the DRAC, along with the speedometer of course.
    It will output 2000 or 4000PPM for speedometer drive, so if the aftermarket speedo you are looking at needs either of those, you should be good.
