What is all this crap? emission vacumes etc
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DUKE, Feb 8, 2003.
  1. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    OKay, just messing around cleaning stuff up. I got a new intake and carb (idle/quad) and Im getting ready to pu on and I am wondering what my mess of vacume hoses and stuff do. Most are broken, pluged, or loose. Anyone have a picture of what an 85 350 should look like. Do i need these? I have no emission laws, so if i can get rid of them in return for power and or efficentcy sake I would love /forums/images/graemlins/grin.gif some guidence. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yues ypu can, only really need line for vacuum advance if equipped, and for auto trans mod valve, and for air cleaner snorkel motor and thermac switch if so desiredor equipped, most ppl dontuse em unless climate is very cold for long periodsof time and if manifold heat stoveis stil intact.
    you should keep charcoal canister hooked up, really, it sucks in fuel fumes from tank and fuel pump for that is three port one instead of old style two port one
  3. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    Would you like to explain the charcoal filter again, this time using proper grammer and complete sentences?
    andy
  4. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    It's used to suck vapor out of the tank on the simple ones. The not simple ones have hoses running all over the place sucking vapor out of the air cleaner and anywhere else you can imagine. The simple canister has two ports, one for the fuel tank and the other to go to the carburetor/TBI. You can steal the canister off a TBI motor, it's small and only has two ports.
    Putting the canister back on can be a chore. You've got to find a vacuum source that isn't going to try to make your gas tank cave in. I ended up going with a ported vacuum that doesn't produce as much volume. I used to have a serious problem with producing vacuum in my tank... on the order of starving my electric fuel pump and making my gas tank make weird noises. I even used a gas cap from an 89 TBI that's supposed to flow more air. And I only have 12" of vacuum at idle as it is (yeap, got stiff power brakes).
  5. 4DiggerDan
    4DiggerDan 1/2 ton status
    Feb 2, 2003
    103
    Montucky, USA
    The only other vacuum line that needs to be connected is the one from the back of the carb to the vacuum braking booster.
  6. Langosta39
    Nov 8, 2002
    156
    Moscow, Idaho
    So is this vapor-sucker an important thing or can I run without it and not have anything funny happen?
    andy
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,068
    479
    Grand Rapids area
    There's supposed to be an emissions sticker under the hood. It shows all of the vacuum routing.
    Actually, the easiest thing is to reconnect everything to return to stock. Disconnecting stuff often seems like a good idea, but can lead to unforseen problems. For example, I think the mixture requirements are a little different for EGR/non-EGR. All of the emissions stuff is not costing you much power. Even the A.I.R. pump consumes maybe 1 hp. It's usually the heads or the compression on "smog" engines that makes them dog, not the rat's nest of vacuum lines and valves.
    That being said, I have disconnected the A.I.R. system entirely and have not found any bad side effects.
  8. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    Yeah that sticker has probably been unreadable for 10 years. THanks for some of the info. I am not too sure it helps, as thats kind of the way it ended up anyway. cool
  9. daimok
    daimok Registered Member
    Jul 18, 2002
    40
    north carolina
    same boat here , cant read the sticker , called GM and they said they dont have them. Haynes manual says to look at the sticker for hose routing. ODD though that the guys that do my inspections have a book on it - half of my vacuum lines go nowhere but look like they are hooked up. $700 worth of tires got me through the first inspection , got lucky with second , guy was a off roader too
  10. dyeager535
    26,975
    Hey, I got an idea, why don't you cut him some slack? If you had read some other of his posts recently, you would have noticed that he has keyboard problems.
    No reason to get pissy with someone that quick.
  11. dyeager535
    26,975
    Another issue that I've run into is that if you ever want to sell the vehicle, you may not be able to sell it to someone that lives in an emissions testing area if the stuff has been pulled.
    Seems odd, but since I live in one of those areas, it's come up before.
  12. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Having a bad day Mr. Angry Lobster39? Sure hope I never make any mistakes /forums/images/graemlins/eek.gif
  13. Langosta39
    Nov 8, 2002
    156
    Moscow, Idaho
    Sorry! Didn't mean to come across like that!
    And thats Mr. Angry Hummer39 to you, Langosta as you know is Spanish for Lobster, and Lobster in German is Hummer. The 39 is from 395 which is the cubes of the 6.5 diesel in a Hummer, but the 395 didn't totally fit for my AOL screenname when I first started using the internet back in 1993/4.
    ANYWAY, is it bad to have a lot of pressure in your tank or should I run a vented cap? Or is it venting itself now that I took out the "black box"?
