What is "anaerobic-type" sealant?
Discussion in 'The Garage' started by mofugly13, Jun 28, 2003.
  1. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    What is \"anaerobic-type\" sealant?
    I'm replacing my rear main oil seal and the manual calls for me to use an "anaerobic-type" sealant on the mating surfaces of the cap and block. What is this stuff? I have various RTV, loctite, form-a-gasket, and other types of sealant, but nothing says "anaerobic-type." What are they talking about? /forums/images/graemlins/confused.gif
    /forums/images/graemlins/usaflag.gif
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Re: What is \"anaerobic-type\" sealant?
    Sounds to me like some sort of sealant that doesnt need air to dry... /forums/images/graemlins/confused.gif
  3. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Bingo
  4. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    got any examples?
  5. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Matt,
    "but nothing says "anaerobic-type." What are they talking about? "
    Loctite is exactly what your looking for.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Loctite is an example of an anaerobic substance. It cures in the absence of oxygen. But I'm not sure that it is something that is designed to be used as a sealant. But I'll bet if ya spend a little time poking around on www.loctite.com that you'll find the info you need. /forums/images/graemlins/cool.gif
  7. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    Thanks fellas. /forums/images/graemlins/thumb.gifLoctite is what I ended up using 'cause it's the only thing I had that I knew would set up without exposure to air.
  8. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    GM Gasket Maker part # 1052942 is good too
  9. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    They are correct - it cures without air.
    Commonly used to seal areas where clearances are needed to remain to-spec. For example, current model year Transfer Case-halfs.
    I kinda thought it might be good to use on spindal to knuckle surfaces. You know how ruff that can be to separate when the get 'em rusted up. 'Don't know, it might not work as well as I'd imagin.
    Anyway
    We use some kinda red stuff /forums/images/graemlins/grin.gif, never looked at the lable.
  10. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    when rebuilding the tranny in my ford SHO, i had to use anaerobic-type sealant to bond the housing peices, I got a tube at my local ford dealer. I believe it was red, & alot thinner than gasket maker.
